Aux switches wiring
GRPinehurst
Pinehurst, Texas
2022 Ford Bronco Outer Banks SAS
I'm unsure if it is available in every model, however, you can the Aux switches to an Outer Banks in the build and price.
the paws
Donald
South Bend, IN
2018 Colorado
Be careful about light bar watts. LED watt ratings have nothing to do with volts and amps. LED watts are Lumens divided by their efficacy. Best way to check things is connect your light to a battery thru an ammeter. You will find that the actual watt draw is about 1/10 the light rated watts.
https://www.rapidtables.com/calc/light/lumen-to-watt-calculator.html
