Aux Switches
jackb10
Chicago
2021 Bronco Outer Banks; 2019 Ranger XLT
I am installing the ZroadsZ rear bumper/dust lights and it came with a massive wiring harness with a switch, relay, fuse, and leads to the battery for power.
I have the auxiliary switches and would I be right to assume that the power box that all the aux wire runs though would already be set up with fuses, relays, and power that I can just hook to the wiring harness in the bronco? I already installed pod light by the side mirrors and hooked right to the aux wires and works great.
I’m not a mechanic so just looking for advice.
Regan
Regan
Bend, Oregon
Murano and 08 chev Duramax
Yep, each color coded wire is fused, I know yellow is 30 amp at #1, then a 15 and I think the rest are 10 amp. This is on Bronco Nation, not sure who is correct. Owers manual consistent with this also. Bottom line, first two are higher amps 3-5 the lower amp fuses.
Bronco Aux Switches Bronco Switches
da_jokker
Jeep Wrangler JKUR
Bronco Aux Switches aux switches diagram
