Auxiliary Switches - alternative location?
NonfatWombat
Trophy Club, TX
'14 Jeep Wrangler Rubicon; '17 Ford Focus SEL
I may have overlooked an image that already answers this question (so many out there now):
Where are the auxiliary switches located on the Base, BB, OB, WT, & FE?
Advertisement
Paint
Jack
Oklahoma
Tundra
Vehicle Showcase
They're optional and they only go in the overhead.
NonfatWombat
NonfatWombat
Trophy Club, TX
  • Thread starter
  • Thread Starter
  • #3
That's kind of what I thought. Although, the breakdown chart shows them standard on the Wildtrak and First Edition too but it doesn't specify "overhead console" like the Black Diamond or Badlands.
jehines3
Easton, MD
Toyota Highlander & Lincoln MKC
Has anyone confirmed how far these aux switches are wired into the Chassis? Is there a location under the hood or in the rear cargo area that you pick up from? The concept is awesome. I just don't know how ford does this in the commercial line-up and if the bronco will be the same?
jboes13
Joshua
Van Wert Ohio
Fusion Hybrid
If it is anything like their super duty aux switches. The wires will be cut and shrink wrapped underneath the steering wheel(just above gas/brake pedal).Typically tucked up in there just enough to stay out of the driver's feet. Sorry if that is an overly confusion description. Best I could think of at the moment lol
damarble
Spokane
01 Sport Trac, 13 Edge, 09 Focus, 07 Explorer
Alternative location? The Filson put them here, even with the OEM aux switches equipped. Things that make you go hmmm.
Tarjea
Tj
Jacksonville, Florida
Explorer
They're wired up all they way into the engine bay in their own box ready for use.
ZackDanger
Zack
Massachusetts
2014 Wrangler JKU
If the AUX switches are not included, a sunglasses holder goes in its place.
dck82
Memphis Metro
Chevrolet Colorado
I’d rather have the sunglasses holder.
Edit: with the top off I’d want to lock them in the center console so I guess it doesn’t matter.
Chrome_Pony
Chrome
The Great Land
2017 LWN Duramax Z71
That's some home-hobbyist-level electrical shit. Gross. Broncos deserve better than Hazard Fraught.
If you don't want to pony up for AUX switches and can find space the Feniex Mini 4200 will give you six switches for about ~$100 to work with with two of them also having strobe capability. I run them in my Colorado for auxiliary lights with a couple doing double duty as plow flashers.
If there's a downside, it's that the head unit doesn't power up on ignition, and requires a manual press, but that's also how to switch from standard operations on Circuits 1 and 2 to strobe on 1 and 2.
Silver-Bolt
Bill
Portland, OR
2018 Ford Raptor
The Aux switches on the Raptor have two connection points. For items inside the cabin there is a set of wires terminated behind the glove box. For outside the cabin there is a set of wires terminated near the firewall on the passenger side.
JesseS
Jesse
Northern California
Jayco AY26, Honda F6B, CR-V
I was hoping they would terminate in a waterproof box under the hood with relay sockets and a pre run power wire.... But that is to much to hope for I guess.
Silver-Bolt
Bill
Portland, OR
2018 Ford Raptor
They are connected to fuses/relays. All you do is make sure the accessory you are installing is grounded. Connect the power wire from your newly installed accessory to the Aux-Switched wire and you are done. The amp rating on the Aux switches varies. 2ea 15 amp, 2ea 10amp and 2ea 5 amp.
JesseS
Jesse
Northern California
Well, that is the way it is supposed to be done, but the way Ford has been doing this roll out I wouldn't be surprised if you had to add your own relay's and fuses. But one change I will make is to replace the fuses with auto resetting circuit breakers of the same amperage.
Raptor911
Raptor911
Ashburn, VA
2019 Raptor, 2018 BMW M2
sir ... you don’t know what you are taking about. Ford had been using Auxiliary switches for over 10 years in their trucks and they are awesome.
I have no idea why everyone on this forum just assume the worst. No manufacturer would put switches into their vehicle and then expect you to run power and fuses to them.
please relax.
Advertisement
Advertisement
