- First Name
- Rod
- Joined
- Aug 2, 2021
- Threads
- 8
- Messages
- 836
- Reaction score
- 1,255
- Location
- Gilbert, AZ
- Vehicle(s)
- Gen 6 Bronco - Jeep JKU - Wrangler LJ (sold)
- Your Bronco Model
- Outer Banks
Yes, 4" coax for the dash and rear pod and 6.5 for the kick panels. I would shoot for the highest efficiency along with the tone and detail you like. It can be difficult, but if you have a decent set of headphones (or good speakers on your PC) go to:Is there a way to do a simple upgrade of the base system without getting into adding amps or difficult removal of interior pieces? I.e just swap to upgraded speakers at the same impedance?
https://www.crutchfield.com/g_51200/4-Speakers.html?tp=102&fa=1#&nvpair=FFSpeaker_Size|4
And you can listen to their output as recorded using their compare and listen function. I usually just go down the list and add the first 4, and then keep my favorite favorite and then add 3 new and keep doing that until I have the one I like the best.
Important to use "Equal Power" when listening so you can see how a more efficient speaker performs since we are looking at building with the factory amp and limited power.
