- #301
1. There is no work around. You have to remove two screws then it pops out. Its a bit tricky, there is an angle that your driver needs to be at, its not intuitive. Make sure your using the correct torx bit too, I dont remember what it was been a while. T20?Awesome write up and directions
Setup mine the same exact way except for the center speaker.
I have a couple questions for you if you don’t mind
1. Is there a work around on removing the center dash panel? I can not for the life of me remove those screws! I can’t see in there and every time i think i have it i dont so frustrating! I probably stripped the bolt already.
2. Mind sharing your sound settings
Treble, bass, fade etc….
Thanks again for this thread
2. Im away from my Bronco this week, and honestly I play with it often so they change.
