cmcbronco
cmcbronco
Illinois
2012 f-150 FX4
I replaced my front speakers and added the kicker key 200.4 earlier this week and started on adding the sub enclosure today because Tasca Ford finally got it to me.
One thing I noticed is that my Big Bend panel has a carpet/sound deadening below the cubby hole that isn't on your base model-that is gonna make it a bitch to get the the cubby mount off with a Dremel.
The other comment I had was about the fasteners...I noticed that people are complaining about "breaking" the upper one in the photo-to be honest I think they are made that way-the one part separates leaving a part in the sheet metal. I was able to pull out the stud part in the sheet metal using a pry tool and snap them back together with no issues.
I think the fasteners were breaking at the part that was pushed through the metal. If that pulls out it’s usually f’d.
Advertisement
Sherminiator
CNJ
2022 Ford Bronco Big Bend
Well I'm about 85-90% done-I just need to fab up the screen for the opening and reinstall the panel. I also need to run Audio test for the Key 500 also
Here is where I stand:
I winded up mounting the Key500 vertically so I wouldn't run into any space issues. You need to remove a harness clip, but that is about it outside of drilling pilot holes.
OMFG this set up is freaking obnoxious! I freaking love it! I still need to play with the audio levels, but it puts out a perfect amount of base and it seems like it woke up my kick panel bass too, but I'm not sure why, outside of the harness being completely plugged in the rear amp.
MannyG20
Ted
F-150
Like @Sherminiator I am about 90% done. I just have to fab up a speaker grill and put the side panel back on. I have 4dr BL with the base stereo. I am not going to repeat all the excellent advice and instructions that has already been given in this thread, but I thought I would pass on a few things that I encountered that might be helpful to some.
1. Running the power line from the battery: I have the 7 MT transmission so I don't have the empty grommet that the 10sp auto people have. In the 7MT you have to pass the power line through the main electrical grommet. You can either slice through the 'main' part or use the small 'tit' that sits in the 1 o'clock position. I elected to use the 'tit'. 3 1/2 hours later I had the power line through the firewall. You have to go through an outer and inner rubber wall. The rubber is very grippy and thick. An 8 gauge wire is not stiff enough to make it through. I tried several methods but finally got it through by duct taping the wire to a small screwdriver and passing them both through.
2. I ran the power line down the driver side and the audio wires down the passenger. I found it easier and quicker to just remove all the interior trim rather than trying to fish the wire from the front area to the rear. I didn't remove the driver side cargo area panel. I didn't want to risk breaking the white fasteners so I did fish the power line from the rear door electrical channel to the cargo area - it was not that difficult.
3. I chose to mount the 500.1 amp to the sub enclosure. All I had to do was fab a mount out of a plastic cutting board - very easy. I like the mounting spot right behind the tail lights but I didn't want to have to move the wiring harnesses that were there and the sub enclosure has the mounting screws already.
4. In order tighten the upper left hand bolt on the sub enclosure for the 4dr soft top set up you have to totally remove the soft top and remove the passenger side soft top mounting bracket. I took a picture of it before I removed it but you need to mark the position of the bracket before removal. The soft top mounting bracket can move in all directions so when I reinstalled the bracket the soft top would not latch - I had to remove the soft top again and move the bracket up about 1/4 inch. (the bracket I am talking about is the bracket the soft top sits on - it has the guide pins).
5. Also - when removing the soft top please remember to lock it down before removal and don't ask your wife to help you if she is petite and under 115 pounds - it will not go well for you, your marriage, or your Bronco.
6. Wear hearing protection when running the Key algorithm for the sub - it is loud.
7. Use a thin jigsaw blade to cut out the 'notch' in the side panel. This works well.
8. When cutting the cubby hole out do exactly as @cmcbronco described. Be sure that you start slow and keep a tight grip on the Dremel - it will want to dig into the side panel itself it.
9. Go ahead and add extra wiring to the white/brown aux wire that runs from the aux switch panel (see picture - yellow wire). I intend to place this is a spot where I can grab it without taking the side panel off.
The system sound amazing. It is the best sounding system I have ever had - better then my wife's Lexus. Thanks again to everyone here.
Sherminiator
CNJ
I didn't have much luck using the dremel setup that @cmcbronco suggested-mine was getting bogged down cutting the plastic or getting hung up on carpet mat.
What I winded up doing is using a coarse cutting bit like this to cut the tabs off the cubby back, then pulled them off using a trim tool then cut the the mounts off with a sprue cutter
Another tip is when you cut the notch out, your plastic might mar up leaving grey/white spots from cutting. Its an easy fix-apply some heat to it and it will turn back to a nice black plastic color like it is supposed to.
I also got some grill material from amazon that was aluminum-I wanted it be fancy so it would fit flush with the opening...but it was an almost total fail. The mesh snapped when I was trying to bend it into shape. I winded up salvaging it by just cutting a piece of it to cover the hole, had some dynamat rubber under it so it wouldn't vibrate and taped it into place so I can figure out an alternate course of action or someone might do an aftermarket one? I'll get a photo later of it.
Pakman72
Geneseo, Illinois
When You added the Memphis audio woofers to the kick panel, did you keep them wired with the dash speakers or use them with a separate channel such as the rear of the kicker key amp?
Advertisement
cmcbronco
cmcbronco
Illinois
2012 f-150 FX4
I kept them wired with the dash speakers. I wanted some more power to the rears so I didn’t do bi amp mode on the kicker. I may change it up some day but like the sound so far.
cmcbronco
cmcbronco
Illinois
2012 f-150 FX4
I think at some point I may try to find the B&O panel and just replace the whole piece so it looks 100% factory.
Sherminiator
CNJ
This the end result of what mine looks like with the panel installed
Tombky
Thomas
2Conline!
2022 Bronco
Did i spend too Much ? Yes ... worth every penny.
Focal K2 Comp for the front.
JL 4 channel amp
Kicker slim 8
Alpine 300w mono
Pod speakers...... STOCK. who cares no sound from them anyway...
3 hours placing kills ... not for the sub but for the k2 woofers... rattles all over front of the bronco.
California waiting
Kevin
NorCal
First off I want to thank everyone on bronco6g for all the guidance. All the threads and posts helped a lot with this install from suggestions on what speakers to use to how to pop the panels off every little bit helped.
This install was full of trial and error, and trust me there was a LOT of error. I decided to make a write up to help people so they can learn from my mistakes.
I knew before I even took delivery of my basesquatch that I was going to upgrade the audio. I took a LOT of time reading through all the threads here before I decided on anything. Eventually I decided to take somewhat of a different route that I’m sure others will try but haven’t yet.
I did upgrade all the 4” speakers to kicker KS series. I was between these and the infinity reference. I had the infinity in my jeep and liked them but the highs were a bit too much sometimes. I’m glad I chose the kickers as the highs are nice but softer as well. I did put boom mat and poly fill in all of the 4” speaker locations. It definitely seems to keep the speakers from sounding hollow and keeps the sound directed outward. I was very happy with the sound all said and done.
Now I knew I wanted to add some sort of subwoofer as well, but also didn’t want to lose cargo space. At first I thought I’ll just get a powered sub I can shove under the seat. Well there’s really no room for that in the two door. Then I thought maybe I can fit one behind the rear panel where the factory B&O sub would be. Maybe I could even build a custom box and put my own sub amp combo i wanted. When I tore into it I was thinking ya a powered sub would probably fit back here no problem. After reading some reviews I wasn’t sure the powered sub would give me the sound I was hoping for. So back to building my own box….but after taking measurements I realized I didn’t want to spend weeks trying to fab up a box to fit perfectly.
Im usually a do it right the first time kind of guy and I didn’t want to have any regrets about the whole thing, so after seeing a few threads about the B&O sub I decided I was going to buy the enclosure that is actually made for the bronco. I went to my dealer and ordered one as I was picking up some accessories I had ordered previously. I was kind of shocked at the price ($325) but I was all in at this point lol. It came in a week later and if anyone is wondering it does come with the factory B&O sub.
For my sub and amp combo I went with the kicker compRT 8” shallow mount paired with the key 500.1. Everything was coming together…or so I thought. My sub wouldn’t fit in the factory enclosure. Kind of a bummer but I figured I could make it work somehow. I did end up cutting a small bump out off of the enclosure to get the sub to fit. I used a dremel with a cutting wheel and shaved off the very top layer so I could reinstall it after I cut the rest of it off. I used some JB weld plastic epoxy to attach the slim piece I cut off so it would be flush with the rest of the box. You can see kind of what I’m talking about in the pictures. After the modification the sub fit great.
I mounted the kicker key in the same spot as the factory amp. Obviously the holes didn’t line up for mounting so I made a mount for the amp out of HDPE board. Then mounted that to the sub enclosure using the factory holes. I did make a mistake with the amp mount Multiple times. I put it up too high and away from the sub so It was hitting the panel on the corner of the amp. I tried moving it down and closer to the sub, but it was STILL rubbing on the panel. Finally I decided to mount it at about a 45 degree angle. That proved to be the answer. This definitely took some time as I had to re-fab the Amp mount every time. You can see in the pictures the different ways I mounted it. The Key is pretty small but if you could find something smaller it might benefit you if you do a similar install.
The only issue I may have is if I ever have to adjust any settings I’ll have to take the panel off again. I plan on getting everything set where I like it so I won’t have to do that down the road. I do have the bass control knob up front so that should really be the only adjustment I’ll need.
Now as most of you know the interior panel without Lux has a cubby hole instead of the speaker grill and will have to be removed if you decide to add the factory enclosure. It was fairly easy when I figured it out but I did make another mistake here. The insert appeared to have the plastic melted “rivets” that I’ve seen in the front grill letters. I thought I could carefully drill them out with a drill bit. I found out quickly that didn’t work and did make a hole in the panel. What did work was my dremel with a plastic cut off wheel. It neatly fit underneath the lip (see pictures) and I was able to remove the cubby easily after that.
I’m still in the process of fabbing up a speaker grill. I have some expanded metal that I bent up at work and I’ll plasti dip it black and it should look pretty close to factory.
I’m very satisfied with the way the sub sounds. With the new speakers it really rounds out the low end which the bronco really needed. I still have a little adjusting to do with the key algorithm which I’m still learning about but I was still very impressed with the initial sound. For an 8” sub it has plenty of punch.
Anyway I hope this will help anyone with the same idea I had for adding a sub that doesn’t take up precious cargo room. If you have any questions feel free to ask!
EDIT:
Still on this project believe it or not 😂, but wanted to share some info as I’m closing in on completion. After test fitting the panel about 20 times now I’m almost rattle free. It’s a tough task as the panel is basically right on the sub enclosure.
I didn’t realize it but the lower lip of the cubby hole will also need to be cut out(see photos) as sub travel definitely hits the plastic making a terrible rattle. After I did that I decided to make a ring out of some left over hdpe board and added some foam on the outside of that as well to allow the speaker to travel freely. Worked out great. Some of my process didn’t get pictures so i apologize.
my remaining rattles I’ve determined are coming from the plastic clips that hold the panel on. Any light pressure stops any noise coming from the panel. My plan is to change the clips and I think I’ll wrap the round part that contacts the panel in some cloth tape. I think this will take care of my issues. Really the rattles only happen when I turn the sub all the way up which I’ll rarely do but I don’t want any rattles. It will drive me nuts haha.
my home made speaker grill I think turned out Nicely as well. Gives it a finished look that appears factory. It’s just some expanded metal that I bent up at my shop and I hit it with a few coats of plasti dip. Youll see it in the picture and don’t mind the green tape. I was just marking where the panel clips are.
UPDATE:
Well I ended up going all the way with my audio upgrade. Installed the kicker 200.4 from plug n play with new Memphis audio MJP6’s for the kick panels and Wow….I thought I was happy with the way it sounded with just the 4” kicker speakers and the sub. This was a game changer when it comes to the sound. Really brought the new speakers to life and centers the sound stage perfectly. The sound is amazing now!
just a note if anyone plans to install the kicker key 200.4 make sure you tap your high level inputs BEFORE the new kicker key 4 channel. I had them still tied into the kick panel wires and my sub sounded terrible. Best way to describe it was it sounded sloppy especially when turning the volume up higher. The amplified signal that was being sent was determined to be the cause of the issue. So tapping before the 4 channel is necessary and also per recommendation from PNP a resistor was also installed for the sub speaker input. Basically tells the factory head unit to keep sending signal to the speakers.
Im extremely happy with how everything sounds now if you’re debating going all the way do it. Definitely worth the money. I’m in over 2k now but damn it sounds good so no regrets😂.
Also thanks to some sticker fab leftovers I came up with a clever way to hide the hole I made in the rear panel.
good luck to anyone else taking this route if you need anything feel free to ask. Thanks!
Can I get the part number for the B&O sub enclosure. My local ford dealer part department isn’t the greatest. Thank you great article!!!
Advertisement
MannyG20
Ted
F-150
Here is my finished project. I took a piece of speaker grill and fabed up a DYI OEM grill. It came out good enough. My mounting board for the amp was too big and I had to cut it down to get the side panel back on. Glad the project is over and very happy with the results.
BTW - the 500.1 amp seems to run hotter than the 200.4 amp. Has anyone else noticed this?
Sherminiator
CNJ
what did you use for your grill material?
MannyG20
Ted
F-150
