FourHorses
Currently own 6 Fords
I like the meaty look of the BFG's and the optional wheel better than the Sasquatch's, I like the look of the 35" better.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Ford Bronco Badlands 33" vs Sasquatch Stance Shots + Suspension Parts Numbers IMG_0656.JPG
So maybe 1/4" or so higher suspension on the Sas. How were the two equipped? Were they both Badlands? Same engines? Same trim levels?
Bottom line - wider wheels and taller tires on a manual Badlands and your pretty much have a sasquatch without the sticker.
Werkedperformance
Werkedperformance
Philthy
www.instagram.com
Badlands 4dr 7MT
left is big bend sasquatch auto 2.7
right is manual badlands 2.3 lux
Dads_bronze_bronco
Considering a 2.7 Big Bend has a curb weight between 4639 and 5170, and a Badlands 2.3 has a curb weight between 4965 and 5198, I'm going with weight differences for that 1/4".
@North7 - keeping my bet on no difference - just weight variations and a 10mm bumpstop. There may be spring differences, but people compared springs when the JKs came out and there was a lot of variation. Yes the Rubicon springs are heavier (1/2-3/4" lift), but different Rubicons had different springs when compared.
Hoping to see it with my own eyes next Saturday.
webspoke
Stan
Pilot Point, TX
F450, GT350
As a future 2.3 manual badlands on 33's owner, I think a spring swap will quickly be available to provide a little 1-2" lift for a clean 35" upgrade. Springs should be cheap for popular/volume applications like this, my mustang springs were less than $300. I saw some other suspension pictures posted that show shock differences (reservior positions) and possibly minor length differences, but its probably not a big factor. Another option is running 33x12.5x17's to get the width and stance, but keep the height and clearance similar.
Gutter Clown
Explorer
I looked at the Badlands with 33" at my event and could barely fit my fingers between the back of the tire and (what I think was) the control arm. Could be wrong on the component name as I am not very mechanically inclined on vehicles.
The SAS did not have this part and had plenty of clearance on the inside of the tire.
VelocityBrew
Minnesota North Metro
22 Badlands, 20 Passport, 16 1190 Adventure
Just a quick visual for you
Ford Bronco Badlands 33" vs Sasquatch Stance Shots + Suspension Parts Numbers 1619269653637
VelocityBrew
I ordered the BL with optional beadlocks. As much as I tried to love the huge SAS flares, I just couldn’t do it. Swapping tires on day 1 to BFG M/T 285/75/17. If I need an 1” or so lift, I’ll add it.
Same boat, although I am going to wait until the stock 33's are in need of replacement for 34's. Thinking 1" spacer or different wheels with a +30 offset to start though.
Werkedperformance
Werkedperformance
Philthy
www.instagram.com
Badlands 4dr 7MT
I can confirm the entire front strut is different between a 33 tire Badlands and a Sasquatch. The part numbers are different the spring perches are mounted at a different height, the reservoirs are flipped. rear shocks are not as drastically different visually however might be. I got part number pictures, ill try to get those posed on the ESCV thread.
BadSquatch21
PA
Land Rover and Porsches; '22 Mansquatch
This is due to wheel offset. Sas has an 8.5" with +30 and badlands has an 8" with +55. I calculated the Sas should have .73" more clearance off of any inside suspension components.
edit: velocitybrew beat me to it with his diagram.
BadSquatch21
PA
Another future 2.3 manual Badlands owner here too. I'm thinking RTR 17x9" wheels with +30 and 305/70/17 (34x12") tires. Will give the width and poke without going to a full 35"
VelocityBrew
Why must you make me now want a 12" wide tire :LOL:
