Personally I like the Sasquatch wheels over the aftermarket. My concern is not knowing the backspacing compared to the Method wheels to see if 37's are going to turn lock to lock before rubbing so not to interfere with the trail turn.
The Optional Badlands wheel is a 17 x 8” wheel, with 6 x 5.5” (or 6 x 139mm) with a 55mm offset and 6.66” of backspacing. Not sure about the Sasquatch wheels.Personally I like the Sasquatch wheels over the aftermarket. My concern is not knowing the backspacing compared to the Method wheels to see if 37's are going to turn lock to lock before rubbing so not to interfere with the trail turn.
@broncoSJ- I'd like to do this same setup. So only unknown then is if any spacers are needed and/or a lift?The Badlands overland concept was non Sasquatch with 1552 wheels and 35s. 1552 emailed me size and offset. “17x8.5 6x139.7 ET0 option” (Traverse Rims). I’m probably going Badlands non SAS and adding 35s as soon as I get it home. Mostly because I don’t love the SAS rims and those new MT wrangler tires are new for the bronco.
Using the offset listed I don't believe spacers would be necessary. As far as a lift goes, if you're running 35's or 315's I don't believe a lift is needed with a Badlands, probably just unbolting the front crash bars. The concept def didn't have a lift. Nobody will fully know until they show up in peoples driveways and people start trying things. I know I'd going to have wheels and 315's ready to bolt on my Badlands when it comes home.@broncoSJ- I'd like to do this same setup. So only unknown then is if any spacers are needed and/or a lift?
I would put on a 1 inch body lift and 37s with new rims that have the appropriate backspacing--which I, admittedly, don't know yet. I did it with 12.5" wide 35s on a JK and less backspacing.I think there are a lot more factors than that. Just because you have a 1" increase in tire radius, doesn't mean you can get away with only 1" more in lift and not have major problems with rubbing (a 37 is wider too). There's not much room for that 35 to begin with stock. Then you change the CV angles...and do you want to run a spacer lift to begin with? I doubt very seriously that people just adding a 1" spacer lift and throwing on 37s are going to be happy, or have a functional truck for off road.
We're talking about the Badlands, specifically, which has the 210 standard.I'm still awaiting the revised pricing, but..
I thought to order the D210 Front axle you had to have the Squatch Package?
If there is different squatch crash bars I assume you can just order these separately?Do we really think there will be different crash bars for every tire size? I would not think so. For certain, there won’t be different mounting locations. At the very most you would have to add the Squatch crash bars. Now, going to 37’s may be another story.
No, the crash bar extensions which come bolted on non squatch Bronco orders and are removed When you order squatch. There is only 1 size and it comes when you don’t squatch, but looks easy (2 bolts on each) to remove.Do we really think there will be different crash bars for every tire size? I would not think so. For certain, there won’t be different mounting locations. At the very most you would have to add the Squatch crash bars. Now, going to 37’s may be another story.
on the Sasquatch package they remove the crash bars altogether. Theory is that with the larger tire it provides more crash absorption in the event of an accident thus they aren’t needed to pass safety standards.Do we really think there will be different crash bars for every tire size? I would not think so. For certain, there won’t be different mounting locations. At the very most you would have to add the Squatch crash bars. Now, going to 37’s may be another story.
Ok, I guess I don’t recall seeing pictures without the crash bars. Of course at my age, there is a lot of things I don’t recall anymore!No, the crash bar extensions which come bolted on non squatch Bronco orders and are removed When you order squatch. There is only 1 size and it comes when you don’t squatch, but looks easy (2 bolts on each) to remove.
Here you go, this is a squatch chassis and this is with the crash bars not installed. on a non squatch the crash bars are added here with 2 bolts.Ok, I guess I don’t recall seeing pictures without the crash bars. Of course at my age, there is a lot of things I don’t recall anymore!
In a conversation with Dads_bronze_bronco, he mentioned the offset of the Saquatch wheels was stamped 30 when someone had crawaled under it & looked. This is on an 8.5 wheel widthThe Optional Badlands wheel is a 17 x 8” wheel, with 6 x 5.5” (or 6 x 139mm) with a 55mm offset and 6.66” of backspacing. Not sure about the Sasquatch wheels.
That’s great, I missed that one. I could have sworn I saw them on Sasquatched Broncos, glad to hear they did away with them.on the Sasquatch package they remove the crash bars altogether. Theory is that with the larger tire it provides more crash absorption in the event of an accident thus they aren’t needed to pass safety standards.
