https://www.bronco6g.com/forum/threads/bronco-bolts.17472/page-5#post-644875Alright, the moment you've been waiting for...
The little bolt appears to be M6x20
The bigger bolt appears to be M8x30
Learn stuff everday. Thought there was only torx.
I'm going to be nosey, are you taking apart the bumper for some reason or is it just a general question about the bolts? Would love to hear if you are modding it some how.T40 are loose T45 are to big. Are these a special size? I don't know of any thing in-between.
oddly enough, no. There are other torx bits in there, but none for the mod bumper. Or at least that's what i've heard others sayisn't there the bit in the tool kit that comes with the bronco?
No I was going to put a RC bull light bar that they said would fit, but didn't. And I was going to remove the covers from hooksI'm going to be nosey, are you taking apart the bumper for some reason or is it just a general question about the bolts? Would love to hear if you are modding it some how.
Not close enough, I can use the T40 just didn't want to cam out and damage finishThere is no inbetween size there...maybe the plating or paint is causing the T45 not to fit? How close is it? Will the T40 strip if you tried to use it?
Thanks I will look into that. There are so many options on fasteners nowThey are probably Torx plus. Google it.
If you buy a set, might as well get the tamper proof Torx plus for future projects.Not close enough, I can use the T40 just didn't want to cam out and damage finish
Tool companies needed more revenue so they invented a new bit style to sell. lolLearn stuff everday. Thought there was only torx.
