Badlands onboard air - is there a mount for under the hood for ARB air compressor?
Jwill66
jimmy
Parkville
Ram
I have been looking at the ARB compressors is there a mount for under the hood?
Rough Rider
2018 Mustang Convertible
They had one at the Easter Safari reveal. They may still be working on it. You can drop them a line and let us know though!
Exomodo
Ryan
Marquette, MI
Ranger
Be aware that all the failures I've heard of are underhood due to heat and grit, the ARB twins are too expensive for what they are and placing them where they tend to fail...
Destroyer
2002 Chevy SWB NBS, 2022 Bronco
I doubt anyone makes one yet. I have a ARB dual compressor under the hood of my JK. If I was to do it again, I'd probably mount it inside the cab somewhere like under the front seats or in the storage area behind rear seats. After a day of wheeling with very low speeds, the compressor gets VERY hot in the engine bay. Were talking immediate burns to your hands on the aluminum cooling fins if you touched it. So much so that I usually have to give it a few short breaks to fill back up my 37s.
604Bronco
British Columbia
www.bronco6g.com
Would this fit in the rear storage compartment, under the floor of the cargo area?
Exomodo
Ryan
Marquette, MI
Ranger
I would mount it to a drawered box with Anderson [electrical] connectors that I'd remove from the vehicle when not in use, and be useful in other vehicles. Place it on top where it would get plenty of airflow. The box would be lashed down to the tie down points in the rear cargo area.
BroncoKong Jr.
Andrew
ARB has shown one but no word on when it'll be produced. And there's been a Ford one listed in accessory catalogues. No word on that one either.
ChrisD
2021 Ford Bronco Badlands, 2021 Lincoln Corsair
That's my exact set up I've been using for years. I originally got it for my JK and have just kept it since. I cut the cables above the alligator clips and installed Anderson power pole connectors. Right now, since I don't have my power run in the Bronco yet, I have been using the alligator clips, but plan on getting power run back into the cabin this weekend, just have to figure out where I want the box installed...
2Jeeps&PatriotX1
Denver, CO
I just bring this along since I switch between vehicles when hitting trails. Not much space under the hood with the 2.7 and like others stated, heat is an issue.
Exomodo
Ryan
Marquette, MI
Ranger
I picked up a Viair 88P for $65 off Amazon, it lives in it's own bag and works for most reasons as long as you're aware of duty cycles and heat management. I have a Viair 10005 kit I bought before the price neatly doubled for my RV and have yet to install it... I may use these in concert on a box top with the tank inside behind the drawers and disconnects. Still chewing on these.
BR0NCO
Randy
Mass
Jeep Audi
I hope we are able to mount one under a seat
R.A.N.M.J.
Rick
Ford Bronco Badlands onboard air - is there a mount for under the hood for ARB air compressor? 885E31B2-76C6-4DFF-B219-78FDF9F93B07
Which kit is this, exactly?
projectbadlands
Robert
Los Angeles
2018 Colorado ZR2
I have a dual mounted underneath the hood... right under my coolant reservoir to be exact. After a good day of wheeling, I refill my 35s with no issue. Sometimes, other people ask to use my compressor as well and I have not had any issues with it.
Destroyer
I should have been a bit more clear. The compressor doesn't shut off or fail, I just choose to give it breaks because of the heat. I've also observed on some occasions that the compressor makes a very distinct and different noise that doesn't sound great. It gets worse the longer it runs, and the more heat it generates.
Also might depend on how much you air down with your 35s comparatively to my 37s. I'm typically only aired down to 17/18psi...will make sure I have a nice set of beadlocks for the bronco so I can go lower
