Badlands - optional wheels and tires look so much bigger..?
calgecko
Sacramento, CA
www.instagram.com
2021 Chevy ZR2 Bison V6
  • Thread starter
  • Banned
  • #1
I'm a bit confused... I'm putting together my build for a 2.7 Badlands 4 door - and the stock wheels and tires look ok, but I really like the look of the optional (non squatch) wheels and tires... both the stock and upgraded tires are both listed as 285/70/17, but one is an AT and one is a MT - but why does the MT look SO much bigger?
Upgraded wheels/ and MT tires:
Ford Bronco Badlands - optional wheels and tires look so much bigger..? badlands VB with upgraded wheels and tires
Stock wheels/AT tires:
Ford Bronco Badlands - optional wheels and tires look so much bigger..? VB Badlands with stock wheels and tires
codydb19
Cody
Silverado
Those optional wheels are my favorite too. But the reason the tires look so much bigger is because of a bug that’s actually showing the Squatch tires instead of the 33 M/Ts. If you look at the beauty ring the tires dont even touch the wheel and they don’t match up.
Bodge Garage
Kris
Millwood WA
1994 Land Rover Discovery, Jeep Gladiator
Do not base your purchase off of the CG image. Look at the specifications for the tire size and compare that to real world examples.
calgecko
calgecko
Sacramento, CA
www.instagram.com
  • Thread starter
  • Banned
  • #9
I think this is what it really looks like
I can live with that !! :love: Thanks... pretty sure I'm close to having my final build figured out
Jtorral
NW
Durango, Focus
If you really want to see the difference visually between 33 and 35. Here is an image of a Jeep with 33's and the 35's next to it.
Ford Bronco Badlands - optional wheels and tires look so much bigger..? 20190816_173314
Rubisquatch
Pittsburgh, PA
2021 Bronco Wildrak
The site is not doing this on purpose to make them look better, the site has a glitch and is placing the 33MT (285/70/17 MT) tires out further in the image than they should be placed. Look close and you can see that when you select the 33MT tires there is this gap (see pic below) between the wheel and the tire (and on the rear gap you can see the desert floor through the gap). When you select the 33AT tires this gap is not there, nor when you select the squatch wheels. This gap is only seen on every BL build when selecting the 33MT.
if you are considering the 33MT tires, they will be the same size as the AT, just a different, more agressive tread pattern.
Ford Bronco Badlands - optional wheels and tires look so much bigger..? 762F7B72-C360-4F59-8772-77DC7FD8D42F
Slide
Tn
Lx570
It’s a bug. What it should look like. I am getting those optional wheels. My question if any one knows. B&P is still all terrain tires with those wheels versus mud terrain. Is that also a bug or do I get a choice of AT versus MT?
Thanks
Ford Bronco Badlands - optional wheels and tires look so much bigger..? E7D40961-AA3C-4D00-A84F-5A8EAE818C52
Lowcountry Bronco
William
South Carolina Lowcountry
Thanks
You can choose the MTs for extra or keep the standard ATs, it's in B&P, think 600 or so extra.
Bronco_joe
joe
Niagara Falls. NY
so are the sasquatch beadlocks wider than upgraded BD beadlocks? would be nice if they displayed the specs for each available rim option on trims
