I found that GIF that showed the disconnect in action during the bronco release night... Looked like way more than 1.4 inches, so I stand corrected!1.4" is lot when you're in the rocks and traction limited
Based off of the listed RTI numbers it looks like the disco will get you around 4.75" of additional travel for both the 2 Door and 4 Door. This is assuming they used a 20 degree ramp.Does anyone actually know what the sway bar disconnect actually adds in terms of suspension travel? I thought I read 1.4 inches, but I can't find it. 1.4 inches does not seem like it's worth it to me... If someone has other data, I would love to hear it!!
Awesome thanks!! ~5 inches is significant!!Based off of the listed RTI numbers it looks like the disco will get you around 4.75" of additional travel for both the 2 Door and 4 Door. This is assuming they used a 20 degree ramp.
2 Door (100.4" Wheel Base): Connected = 560 (56.22"), Disco = 700 (70.28")
Difference = 14.06" increased travel up 20 degree ramp
sin(20)*14.06 = 4.8" vertical difference
4 door Wild track has a height 73", so you should be goodLove the Widetrak any way to lower it maybe .5"???? Thats all I need for it to fit in the Garage.
My Garage is curved and at the lowest point on the sides it's 75" and not a hair more. SO we are close.
This is where I got schooled from First On Race Day:BillyGoat...sometimes I'm told I'm illiterate. I understood both have Baja...the difference in GOAT modes is Badlands has Rock Crawl and Wildtrak has Sport.
once again, the tables above are at best guessesGuesses based on ford Raptor.
I too was wondering about an aftermarket sway bar disconnect. If so I might skip the Badlands. The goat modes are just confusing to me. All I want is 4H and 4L. Some one did mention that you could alter the goat modes on another threadSo my question is how much better will the Bronco be on the road with the Sport mode vs not having that option? That is the only thing I wish Badlands also had. I want the electronic sway bar disconnect and rock crawl mode along with the sport mode while daily driving,
Does anyone know how much better the 2.7 will perform in Sport mode? My other question is how difficult would it be to mod the sway bar on the Wildtrak? I’m finally going to have a 4WD to start getting off road, but I like my heavy foot on the pavement.
Trail Control and Trail Turn Assist come with the automatic transmission.Great Discussion here as I am torn between both trims. I have question about the Trail control, trail turn assist, and trail one-pedal. This is standard on the wildtrak but an option with the badlands. This would be awesome to be able to turn on a dime. Anyone know what option this is associated with? SAS package maybe?
https://www.musclecarsandtrucks.com/ford-bronco-trail-turn-assist-video/
