Bamf hitch install issues?
Ig_bronco
Matthew
Pittsburgh PA
2014 JKU
Howdy folks, curious to see if anyone got and installed the bamf hitch.
https://www.bayareametalfab.com/2021-FORD-Bronco-Full-size-2-Receiver-Hitch-_p_168.html
It's a great hitch heavy as crap. BUT! The bolts are too big as well as the nut. so it appears I need to remove the entire bumper. And the bolts go in from the back which I have to push my exhaust in just to get one seated. I'm pretty smart mechanically but this one has me stumped. I'll remove the bumper but I feel that's excessive for a simple hitch. Tia
Shoresy
Land cruiser, focus st
I installed a different Curt hitch, but would imagine the bolt lengths are about the same…trying angling the bolt head to the side, horizontally, right up against the muffler, and then allow the threaded portion to slide into the hole.
It seemed non intuitive that it would fit better this way, but it worked for me and I didn’t take the bumper off!
Dirtyjed
Orangevale
05 Dmax, 86 FunRunnah, Tiyoda truggy, Honda shi
I can't even get my BAMF hitch to clear my plastic bumper facia.
The only way I can figure out how to make it work is remove plastic, trim to fit, install hitch, reinstall facia.
So I'm probably going to wait till I figure out what rear bumper I want and see if hitch will work or just sell the hitch.
NVCowboy
William
Henderson, NV
Nice looking hitch, except it is recesswd soooo far under the bumper even bike people (as opposed to tow people) are going to need an extension to clear the spare tire. I would also ask bike people to have some sympathy and buy an aftermarket hitch for your racks freeing the wiring for tow people. Don't come at me if you do both. If you want / need trailer wiring, I'm on your side.
Ig_bronco
Ig_bronco
Matthew
Pittsburgh PA
2014 JKU
Fu shoresy 😂😂😂 (jk I love that show)
I should clarify I did all of the above in addition to pushing the exhaust. I am able to get one bolt in then push in far enough to get the nut in to maybe grab a tread and pull the bolt all the way in. But there is a small clip behind it that makes a tight fit also.If that makes sense? There was a member who got the same hitch and said it was great.
Ig_bronco
Ig_bronco
Matthew
Pittsburgh PA
2014 JKU
Lol, I got it for bikes. I already have a Allen sports 4 set. Designed for jeeps
Ig_bronco
Ig_bronco
Matthew
Pittsburgh PA
2014 JKU
Alas after a good stare thinking wtf... I got it. Those we want this hitch word of caution the hardware will work 100% with aftermarket exhaust. Stock you can two bolt it (minus one washer) and it will work. Or rip the entire bumper off and throw in the other two bolts. It's a tight fit. You feed bolts through just one or two threads exposed for the 19mm nut to catch then tighten.
Ford Bronco Bamf hitch install issues? image
Shoresy
I think I understand, yes there is a piece of metal that interferes a bit. Gotta pull the bolt back and just get the nut to snag a couple threads and then keep working at it gradually.
I actually had more problems laying on the ground and torquing to 110ftlb!
now, go have a Puppers!
MyBHinds
Kansas
1976 Bronco
I purchased last year and had a similar issue. Went to Home Depot and bought 1/4 inch shorter grade 5 bolts and was able to make it work. Was able to get the outside books that came with it to work and used the two shorter books on the inside.
BAMF
Jerry
Benicia CA
Two 2021 Broncos
There is no easy way to get those bolts inplace without moving the muffler out the way. to install it loosen the band clamp on the exhaust and moving it forward some giving you room to install the bolt. The two inner bolts are very tight but we didn't want a welded nut in there that could fail over time. If you place the two outside bolts In loosely then the two inner bolts
Holding the nut and washer inplace as you install those bolts starting them is much easier. It should be about a 10min install with moving a exhaust out of the way.
Ford Bronco Bamf hitch install issues? 20220117_091138
Ig_bronco
Ig_bronco
Matthew
Pittsburgh PA
2014 JKU
The plastic bumpers might need trimming slightly.
I was gonna tell the public you reached out after my email but you beat me to the punch. Thanks again for following up.
Dirtyjed
Orangevale
Has anyone tried to put a regular trailer hitch or recovery shackle point in this receiver?
None of the 3 I have will line up if installed in the correct orientation.
Roger123
Roger
VA Beach, VA
Ford Bronco Bamf hitch install issues? 20220122_202632
Would cutting that bolt off some make it easier? You only need one thread showing past the end of the nut.
MFP2241
WV
Instead of cutting the bolts, I went to Tractor Supply and spent $1.94 on 1/8" thick grade 8 washers to create a little space. Worked just fine.
