- M
- Mar 24, 2021
- 10
- 321
- 657
- Prescott az
- 2022 BB,BASE
- Big Bend
- #31
No not even close but street use only...This looks sweet! Any rub?
I cant say for sure on that but I think the average user will be fine clearanxe is better than the average off road factory paxkage on most trucks suvs say like a tacoma....I dont see probs for 70 80 percent of owners...The wheel arches on the Bronco are pretty huge. Trim doesn't change that. Yeah, you can get the rubber on but does it rub anywhere without the lift when actually put to the tests?
How much clearance at the Upper Control Arm?I cant say for sure on that but I think the average user will be fine clearanxe is better than the average off road factory paxkage on most trucks suvs say like a tacoma....I dont see probs for 70 80 percent of owners...
Yup when I xanCan you verify the exact size stamped on the inside of the wheel including width and offset?
That AZ sun with no humidity makes Rapid Red look very different!Its rapid red in az sun !
It looks great! Instant major visual and performance upgrade from the wimpy stock base wheel/tire combo.Updated with some answers:
The crash bars have to be removed just like the sas package...max size 33 to keep crash bars.
These fit great I suppose if you require extreme articulation maybe you want a lift but the 80 percent who dont hard core rock crawl no probs.
Nope I was shocked as well no lift fit geat.
I had a 285 75 17 unused laying around and have a 5th ranger wheel so all good...prefer a smaller lighter spare to rest on tailgate and take stress off tailgate...
Crash bars have to be removed on this size tire just like sas...these pics show the least clearance when tire turned varios degrees.
It looks like those Ranger STX wheels are 17x8 with +55 offset.Can you verify the exact size stamped on the inside of the wheel including width and offset?
it looks like the same as this pic i can get my fingers between it as shown in pic maybe a 1/4 inch closer..perhaps various tire shapes may make a differenceHow much clearance at the Upper Control Arm?
That clearance appeared to be very close with factory 285's on the Badlands. General thought was that was why they went to a +30 for the Sasquatch 315's.
Here's a squatch pic of what I'm talking about.... stolen from the web, the red is not my highlighting, but does point to the area of concern.
i was able to get a tiny rub on a full left turn under some power it was minor seems to be the left wheel just touching the sway bar which is round and thick steel so no real issues... it does work but i do understand why ford used a 30 offset on the sas rim...im happy with it and won't change anything ..i did test it making some sharp turns and hitting curbs while turning with no rub...for an economy wheel package not a bad choiceThis looks sweet! Any rub?
