Base Model Bronco Thread
Walrus
Seattle, Washington
Subaru 2020 Outback
I just saw on the base spec sheet that towing across all drive train options is "TBD".
What is class 2 rated at?
TowingBody StyleEngineTransmissionAvailable FeaturesMax. Trailer Weight Up-to (Lbs.)
2-Door2.3L EcoBoost®ManualClass II Trailer Tow PackageTBD
2-Door2.3L EcoBoost®AutomaticClass II Trailer Tow PackageTBD
2-Door2.7L EcoBoost®AutomaticClass II Trailer Tow Package TBD
4-Door2.3L EcoBoost®ManualClass II Trailer Tow PackageTBD
4-Door2.3L EcoBoost®AutomaticClass II Trailer Tow PackageTBD
4-Door2.7L EcoBoost®AutomaticClass II Trailer Tow PackageTBD
Class II is up to 3500lbs.
Tangent27
Tim
2013 VW Passat 2013 Road King 1987 BMW e30
Let’s see, base 2 door manual ( for 4.46 ) 30k. Auxiliary switch option 700 (?) wheels and tires 2500. ( ish ) So cheapest bronco build option for me would be around 33200 as a guess.
lose out on lockers that I want but probably wouldn’t really need, one goat mode, and some colors.
Not stuck on this trim level but things start to add up super fast.
build tool can’t come soon enough.
da_jokker
Jeep Wrangler JKUR
This would be a modern replacement for my 2001 Jeep Cherokee......... I'm more concerned with ..... mpg....
saw this and made me laugh.. I have an XJ as well and the part of" I'm more concerned with ..... mpg " and XJ don't belong in the same sentence :p
OH-RK
SC
Ram 1500, Sonata
Will you be able to upgrade to either of these rims without upgrading to the sasquatch package? I plan on getting base, only want to upgrade wheels and tires, maybe grill.
5.0Maverick
Todd
Nj
1970 maverick.
Wait, I thought you could upgrade the base with lockers and two inch lift?? Then it just comes down to new wheels/tires. Are the lockers not actually available on base?
Zeta
GA, USA
1997 Jeep Cherokee
Based on the official comparison sheet and the website config leak the only way to have any lockers on Base is to get Sasquatch. Big Bend gives you the option for a rear locker without Sasquatch and Black Diamond comes with a rear locker without Sasquatch.
SwankyTiger
2020 WRX
i keep going back and forth on a base + 2.7/auto/Squatch vs a Badlands + 2.7/auto/Squatch
doing the calculations on rough estimates of the package pricing. The Base with the 2.7/auto/squatch will be between $38-40k and the Badlands would be $45-47k , I like the rubber floor plus vinyl but i assume someone will come out with the plugs for the floor aftermarket and the no tow package is fine since i would go with a bumper with receiver anyway, frame mounted sliders instead of body mounted ones and a winch bumper
BuddysB6g
JAMES
Porsche Cayenne
So many options!!! Decisions decisions... I've never been so excited for a vehicle before! I'm 45 and have never owned a new vehicle, always bought used..I've had 1985 and 1995 bronco, can't wait for my 2021 !
Ideally, so far, I'm going with base 4 Dr, carbonized gray, 2.7... options are undecided due to not really knowing what's standard for sure, but if I get to choose I prefer BB grill with the slots, also I'll probably upgrade wheel/tire myself.
Fuzion2Bronco
Asher
Base Sasquatch
Ford Bronco Base Model Bronco Thread 20200807_235901
I think you need to get Outerbanks Trim to get these Rims.
Zackmd1
Zack
Maryland
1970 Mustang 429, Ford Bronco 2dr Outer Banks
The more and more I have thought about it, its Base all the way for me. Pretty much everything I would want in higher trim levels (vinyl floor, Marine grade vinyl seats, heated seats, 33" tires, premium tail lights, etc...) I can add after the fact (vinyl floor will be ordered direct from ford, marine grade seats can be sourced as take offs most likely, heated seats can be aftermarket when redoing the seats). I now just have to decide on color, and 2.7 auto or 2.3 auto.... Leaning towards 2.3 auto just because of likely cost savings but we shall see when the Build and price arrives. Goal is to be under $30k. Rapid red is currently the leading color (unless Ford is so kind as to add Area 51 to the base model...).
Rigsurly
Coral Springs, FL
Ford F150
I'm thinking about buying the Outer Banks version but want it to look retro. My wheels and tires are
  • 18” Bright Machined Black High Gloss-Painted Aluminum
  • 255/70R18 All-Terrain A/T (32”)
If you are ordering the Base version with the stock wheels and tires:
  • 16" Bright Polished Silver-Painted Steel
  • 255/70R16 All-Season (A/S) (30")
I would like to swap you even up for mine. If you are interested in discussing this please send me a conversation reply
dgorsett
colorado
F250, Mustang, Explorer
If anyone near western Colorado is in this frame of mind in about a year look me up.
OH-RK
SC
Ram 1500, Sonata
What state you located in?
