- Joined
- Jan 21, 2020
- Threads
- 68
- Messages
- 3,642
- Reaction score
- 16,088
- Location
- Spring Branch, TX.
- Vehicle(s)
- 2021 Bronco
- Your Bronco Model
- Badlands
- Thread starter
- #1
https://blog.bds-suspension.com/?p=25136
Coldwater, MI: BDS adds next level performance and capability for the 2021 Ford Bronco DSC Coilover Systems. Designed to outperform on and offroad, these systems build off the stout factory suspension geometry upgrading to FOX 2.5 Performance Elite Series (PES) coilover at each corner of the vehicle. With aluminum-bodies, massive 7/8” hardened chrome shafts, and dual speed compression (DSC) adjustment, the coilovers are specially tuned for 2-Door or 4-Door Bronco models. These coilovers come ready to install right out of the box preloaded with coils and mounting hardware for the shocks and reservoirs. DSC allows for easy tuning of high-speed and low-speed compression valving to meet your performance needs in any terrain and match your driving style. Net lift height varies based on the factory suspension configuration as follows:
Bronco 2Dr w/ Sasquatch package - nets 3.5" of lift
Bronco 2Dr Badlands trim (w/o Sasquatch) - nets 4" of lift
Bronco 2Dr w/ base shocks (w/o Sasquatch) - nets 4.5" of lift
Bronco 4Dr w/ Sasquatch package - nets 3" of lift
Bronco 4Dr Badlands trim (w/o Sasquatch) - nets 3.5" of lift
Bronco 4Dr w/ base shocks (w/o Sasquatch) - nets 4" of lift
Along with the supplied FOX coilovers, BDS has engineered Performance Series upper control arms. The tubular design is specially formed to optimize clearance in a coilover configuration to allow for maximum droop travel along with clearance for a wide range of wheel/tire combinations. Camber angle is corrected at the taller ride height. At the frame mounts, BDS specs vulcanized rubber bushings for smooth, quiet maintenance-free operation in the factory mounts. High-strength FK uniballs add strength and provide more travel than traditional ball joints. BDS Performance Series control arms are finished in a durable gloss black powder coat with an anodized aluminum dust cap. These new systems are design for easy install with clearance for 35-37” tires. Take you Bronco to the next level with BDS and FOX.
These lift system are being pre-launched. Shipping begins December 2021
Pricing appears to be $5,873.85
2Dr:
https://bds-suspension.com/product?kid=1904FDSC
4Dr:
https://bds-suspension.com/product?kid=1905FDSC
Also provides a little info on their future lifts going past 4":
2Dr:
4Dr:
Over 4" of lift there are some additional provisions need to be made to correct suspension, steering and driveline geometry. We'll be offering 4.5" and 6.5" lift height suspension systems to include crossmembers, taller steering knuckles, differential relocation, FOX coilovers all the way around with the goal to allow clearance for up to 40" tires. More to come on these taller lift systems, but expect to see them out early 2022.
