Beach Bronco - What are Your Must Haves & Don't Needs in a New Ride?
BroncOBX
Rick
NoVaStan: Land of the Petulant
www.polaris-intel.com
2012 Ford F-150 FX4; Mavic 2 Pro
In spec-ing out a Bronco for primary coastal road/beach/dune driving what do folks think are the "must haves" and the "don't needs" putting aesthetics aside? Tire/wheel size?
Blackandbluebronco
Christopher
Wichita Falls, Texas
Ford Expedition
The only thing I would want for that would be the washout interior On the black diamond. The badlands would be overkill if thatā€™s all your going to do with it.
Toccoa
Isuzu Rodeo Sport
Maybe get the Sasquatch package to give you wider tires and better clearance. Although, you could do both of those things on your own after purchase with a lift and bigger tires.
MJJ
Sean
Iowa
JL Wrangler Rubicon, Jeep Wagoneer, Colorado ZR2
I think the wildtrak would be a good match but it doesnā€™t allow for vinyl seats and rubber floors which is a must for a beach cruiser. Then again I donā€™t have any beaches near me so it is a non issue and probably why I am clueless as well.
L8apex
www.instagram.com
'14 Focus ST, '21 Badlands
I know it hasn't been listed yet, but I'm hoping they offer a factory ARB air compressor for airing up / down for the sand.
RLW
Robert
Chattanooga, TN
2000 Lexus GS 300, 2022 Badlands, 2022 Honda Odyss
Black Diamond with Sasquatch I think would be ideal for the beach.
Wash out interior I think would be very helpful.
35" tires would give you a little more clearance and a wider foot print. Less likely to sink and get stuck in the sand.
PELS82
NA
My Wildtrak will be seeing a lot of sand so All Weather Mats are a day 1 purchase.
NCOBX
H2 Hummer, Holden Commodore
Wide non-aggressive tires. 33ā€tall 12.5ā€wide
Or 35x12.5 donā€™t go aggressive!
!!!Onboard Air!!! Donā€™t run over 20PSI in sand.
A_Locke
Detroit, Mi
2011 Toyota Prius, 1966 Ford Mustang
If you are doing a lot of sand/beach driving, tire size doesn't matter too much. The 33" tires will work fine. I would also say that A/T's and M/T's will both be capable so don't stress too much over which tire option you choose.
As someone said before, getting an air-compressor to air up and air down your tires is really important on the beach. I'd also recommend traction mats/board. Ford sells them on the "ford performance website." They are a great recovery tool.
The only thing that I would potentially recommend is getting the "beadlock capable" wheels that are available on the Badlands or the Sasquatch package. If you are new to off-roading, beadlock wheels will lock the tire bead in place using bolts, rather than using tire pressure. This will greatly decrease the amount you can air down to which will provide better traction on sand. While you can do basic sand and beach driving without beadlocks, if you plan on doing intense maneuvers at higher speeds, they are necessary. Ford sells beadlock rings which make the beadlock capable wheels have beadlocks. While I wouldn't say they are absolutely necessary, it is nice to have the option in case one day you decide to do more intense sand driving.
GetBucked
Daniel
2014 Focus ST
I just saw this morning, Ford performance has an ARB onboard air kit for $369. I'm not sure if that's a good price or not since I am a total newb when it comes to the off-raod toys.
Ripcurl
DodgeRam 1500 Laramie, HarleyDavidson 48
I echo the washout interior.....Black Diamond seems like a good target, even without Sasquatch....we used to roll the dunes easily in an old stock Cherokee Chief aired down
The stock BD steel wheels are likely more prone to rust (over time....not instantly since they are painted) if you're getting a lot of salt water exposure so maybe the aluminum upgrade if you don't add Sasquatch
Maybe one of the expected options for a Bimini or mesh shade top for the front so you can stack some surf-body-skim boards in the back if that's your thing unless you're adding a rack
Just add some Roth-era Van Halen and you're set for the beach
L8apex
www.instagram.com
Looking at the ARB website the price for just the compressor is $299; so if it's $369 installed w/ factory warranty I'd say that's a deal.
Edit: But I'm also a newb.
BroncOBX
BroncOBX
Rick
Get in, Waldo!
