Beadlock wheels questions
  • Thread starter Deleted member
  • Start date
  • Watchers 4
Deleted member
Guest
Hello, I have a question for those who understand beadlock wheels better than I.
What are the consequences, if any, of using a beadlock wheel on the street? I know these are not road legal; but will the police issue a traffic citation if you have them on your Bronco and are driving on the street? Are they dangerous for street use in some way I don't yet realize? And lastly (assuming you absolutely should not use these on the street under any circumstances), do people uninstall the beadlock rings when driving on the street and then install the beadlock rings when off-roading?
Thank you.
Dragline
GMC Yukon Denali, GMC Sierra 1500, Honda Civic, Chevy C3500
Quite certain Ford factory beadlock rims will be street legal.
BroncoKong Jr.
Andrew
The wheels that come with the Sasquatch package are not actual beadlocks; they just look like them. To make them beadlocks, you'd have to order the beadlock rings from Ford. The stock wheels are 100% legal.
Jp215
James
Pennsylvania
2015 F150
I saw a video the other day that said you have to purchase the actual bead lock rings separately as an accessory as the are for off road use only. I don’t know the consequences for getting caught on the street with them and I would imagine it will vary from state to state. Also one of the videos I saw on the topic did mention actual bead lock wheel on street are illegal in all 50 states. I don’t know how true that is thought. Could just be a cya statement from ford
LorenzeTorres
Lo
Oakland, CA
2007 Toyota FJ Cruiser/ 2002 BMW M3/ 2016 BMW M2/ 2016 Triumph Thruxton R
I guess I haven’t wheel’d hard enough for my tire to de-bead. But I’ve ran as low as 10psi on regular wheels and I haven’t had issues
Deleted member
Guest
@BroncoKong Jr., thank you...but I understand that. I also understand the benefits of using beadlock rings. What I do not understand is why they are not road legal and what, if any, consequences come with using these on the road?
BroncoKong Jr.
Andrew
That's not true. There are DOT-certified beadlock wheels, like Hutchinson Rock Monsters.
High Proof
Troy
2015 JKU, 2018 Panamera
Exactly. I would expect the Ford offered beadlocks to be DOT certified.
