Aaonter
Rick
North Bend
2020 Wrangler JLR
If you look at how the receiver mounts, it isnt hard to see how having a hitch in the receiver and hitting something solid could torque that crossmember.
Gladiator hitch probably mounts to the frame rails rather than a crossmember...
Moral of the story, don't leave a hitch in the receiver...
Yeah, had to climb under my gladiator to make sure I did not just miss the damage. You are right and it has a tubed heavy duty mount that bolts onto the frames on each side not just bolted to the crossmember. It was all good. My 2dr is bolted to the crossmember like the bronco. This is a good reminder to either use a dynamic rope or a strap with a slow pull getting someone else out.
dgorsett
colorado
F250, Mustang, Explorer
Well regardless of how this actually happened, how many times have we come off a ledge or a rock and smack the trailer hitch? I mean most people treat the hitch sort of as a "rear rock slider" :)
I was thinking of ordering that hitch slide to make sure that that gets hit before anything else including my bumper and spare tire... Now I don't know.
Maybe having some reinforcement metal added to that middle brace to keep it from twisting or bending.
I mean I get the crumple zone concept.. this kind of seems like the tie rod problem... I really looking for a weak point where it actually should be stronger than the norm.
I put a hitch slide on mine thinking it would protect the muffler and provide protection in a rear end accident, now I have to rethink...
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
As a long time Tacoma owner, it’s pretty well expected to get frame damage from anything more than a bump if you have a hitch in. Best to leave the hitch out of the receiver if you’re not using it.
Also why I went with the BAMF receiver mount. It’s tucked up tighter than factory. Will be replacing the bumper soon with one with an integrated hitch.
da_jokker
Jeep Wrangler JKUR
I know the hitch on my jeep is exactly like the Broncos..guess they just bolted it to something
Yeah I'm thinking rhis is the fix..i got the towing option so all the electrical is there. Just transfer it to a hitch bumper thats bolted to the fram and I should be able to hit all the rocks I want
BroncoBuckaroo
Joe
Missouri
2017GT350-SOLD, 2013 Ford Edge, 1969 Torino Cobra
I wonder what the difference is between the one for the 2.3 and 2.7 is ?
Flip posted : The part with the green triangle (rear subframe section) is also available. Front section (out of pic) shows 1 in the warehouse for the 2.3 and 1 for the 2.7. Looks like there are one or two full frames now available as well so if you get side smacked with frame damage, it may not total due to part availability.
Lxatoledo
E
Albuquerque
75 EB Ranger
How fast were you going when you hit that boulder?
Check out the mounting...I looked at mine and was like, "Are you kidding me?!?! ". A complete joke.
Los
Disco3
OK so what type of material are they building the bronco with, I thought the frame is one of the strongest part. What! Did they forget to properly hardened it.
Stefanmcd
Stefanmcd
Stefan
2016 Exploder Sport
A few things here.
1. This is exactly why I opted to not get the tow package. That receiver will likely be the first thing that hits in any situation and you lose departure angle.
2. On my Dad's FJ Cruiser we actually cut this rear frame member out and moved it towards the front a couple of inches to help with that. Fully aware that doing so could change how the vehicle reacts in a crash situation. We didn't think it would be too much of a risk (looking back he probably should have made the dealership aware of that when he traded it in........).
3. Where is your muffler? Is it a thing to cut the muffler off on a Bronco? Don't get me wrong, I've ran straight pipes on several V8s, but never of a twin turbo V6....
It's an Afe aftermarket exhaust. Muffler is smaller and further towards the front of the truck.
adamruiz2001
SoCal
Ford SVT Lightning
How did you like the sound of the aFe exhaust? I am torn between aFe Apollo GT series and the Flowmaster American thunder cat back. I think they both sound good in there own way.
SasquatchMansquatch
4 door basquatch
Wow, sorry this happened. Let us know how the repair process goes.
