Best way to remove scratches from the cheap plastic interior?
1970AMCAMX
Robert
Titusville, FL
F150, AMC AMX, DF Goblin
What kind of scratches? How deep?
zombie
New Brunswick, Canada
2021 Bronco Badlands (7spd) 2022 Mustang GT PP
I traded in my Ram for the Bronco. Lol.
The point stands :)
What have you been doing to the interior that it's scratched badly enough that you need to remove them? I can't say I've been doing doors-off off-roading (it's winter here, brr) but I've got not scratches from using my Bronco as a daily driver since I bought it back in Sept.
Lilj4425
Lilj4425
Jacob
Greenville, SC
2021 Badlands Bronco
All over the spectrum in the back. Some scuff marks too. Probably impossible to temove
The point stands :)
Throwing snowboards in the back wasn’t the best decision in the world. They rubbed on the sides of the back tailgate area while driving causing scuff marks and scratches to the plastic.
zombie
Doh, should put your snowboards in bags before putting them inside (I know this is great advice after the fact, lol)
Bronco67
Atlanta, GA
2 DR
Theherofails
Thomas
Phoenix
Yup. Interior scratches easily. Can confirm with my own wonderful scratches all over the cargo area. Anything plastic or harder will mar or scratch the Bronco interior.
It won't be a problem for grocery runs, but packing up for outdoor adventures will surely leave you with scratches and marks .
I bought my vehicle to use, so not worried. But I am excited for that laser cut MOLLE paneling for the cargo area to finally get released.
BroncoAZ
Mitch
21 2 Door Badlands 6MT, 01 Expedition, 24 Tesla Y
I’m thinking of pulling the panels after a while and doing a bedliner spray or coating on them. The factory plastic will scratch and look like crap eventually no matter how careful one is. If I had a base model I’d probably consider using the same bedliner on the carpeted floor right over the carpet. Usually the worst looking spot on my truck is the driver’s side door panel where I kick it when getting out.
Norm A.
Norman
Rhino liner 😎
dmannx
Doug
Carlsbad, CA
2016 Land Rover LR4 / 2021 Ford Bronco Badlands
Seriously - I have a 7 year old Land Rover LR4 that i have driven & used in the same way I do the Bronco & it doesn't look anywhere close to this in the cargo area. These scuffs & scratches occurred after one weekend camping trip. Not sure there is any repairing these - going to buy some adhesive rubber strips and place them in the areas that my storage bins touch the panels.
Pretty cheap plastic for sure.
Ford Bronco Best way to remove scratches from the cheap plastic interior? unnamed-1
Rick Astley
Up Doug's ass
d
Removing scratches from that sort of stuff: I've not found a way. In theory you could sand them down but you'll take the finish off everything and you pretty much can't get that flat by hand so it will have waves/marks.
If you had deep scratches then I use a fresh razor blade to remove the peeled up side and create the negative space and fill with epoxy that's close in color.
I am curious if you took a horse hair brush with short nap and an interior cleaner if you could vigorously agitate the surface and get some of the top marks off. Would shy away from using nylon or boars hair for this purpose (nylon can scratch, boars hair is too soft/expensive).
