For whatever it's worth, at least for my Bronco ('23 2Dr badlands), the hardware you need to remove at the leading edge of the back hardtop uses torx plus 27 fasteners. The install instructions say it's torx 40, but it likely varies by exact year/model (and packages, maybe?). TP27 is not something most folks will have around and it's not a size included in the Ford-provided toolkit (TP30 is, though).
Also, I found that a wood clamp was needed to install the lowering brackets. The hardware that Bestop provided was long enough, but you need to compress the top down against the hard top to get enough thread through to start the nut. Especially if you're doing the install with one person, the clamp is _really_ handy to get the lowering brackets installed (holds it in place while you're threading on the nuts as well as compresses things enough to get enough thread through).
At any rate, a TP27 driver and a wood clamp were necessary in my case, and it took me far longer than it should have to figure that out.
Other than that, the install went relatively smoothly, and the sunrider works well with the TrailRax half rack I have installed. It even has enough clearance (just barely) in the cutouts where the front latches are for an M2M squatch basket to be installed with the softtop hardware for it (still not 100% sure it's fully clearing, though).
(Also, yes, things are super dusty and need a wash. But that's kind of a perpetual thing and I had it out on some dusty forest service roads just before this install...)
