Bestop Sunrider Wind Noise
Snowdogyyz
22 Ford Bronco Badlands
Can’t attest to the bronco version, but the version on my gladiator is great. No more noise than when I have the hard panels on. Maybe they haven’t got the bronco fitment nailed down yet?
TX-Hans
'21 Escalade, '13 Jeep Wrangler, '21 Bronco FE
@Bestop_Team Any input on this wind noise with the Sunrider? I have a brand new one sitting in the box and I'm interested in understanding the issue.
Bestop_Team
Bestop
Bronco, Jeep
Hi there!
You should not experience much wind noise. A soft top, in general, will be louder but if you have issues with your top please call us 800-845-3567 or send us an email at [email protected] and we can get this issue resolved.
- Eryn@Bestop
TheShark
2023 Bronco 4DR Wildtrak, 2023 Maverick XLT FX4
I've had my eye on one of these, wasn't going to pull the trigger until at least spring so I guess I'll lurk and see if anyone else has this issue.
Gloff
Gloff
Sean
San Francisco
www.serramonteford.com
'21 Ford Bronco Big Bend, '03 BMW Z4
Update:
I adjusted the assembly rearward using the mounting bolts, and it made it tolerable, this got me thinking. The latch rotates down and rearward to secure. I adjusted the striker forward using the two bolts and that made it feel more solid upon latching. Striker mount bolts in red, the trim doesn't have to be removed, but it does make it easier, the clips to squeeze are circled in green. I loosened it enough that I could tap it with the ratchet to get it to move. Bolts are IP50 which comes in the Bronco tool kit.
I'm going to mess with the seal some to see if I can make it quieter, but it's much better.
Ford Bronco Bestop Sunrider Wind Noise PXL_20220114_015434294~2
TX-Hans
Hi there!
- Eryn@Bestop
Thank you, @Bestop_Team Appreciate you responding and committing to resolve any issues. Sounds like it's time to open up that big box.
Bestop_Team
Bestop
Bronco, Jeep
Give us a call if you need help with anything else! 800-845-3567
- Eryn@Bestop
Beach_Bum
Ken
St. Augustine, FL
Update:
Any further update beyond what you did here? Did @Bestop_Team contact you to assist?
Gloff
Gloff
Sean
San Francisco
Hazard
Kevin
Nissan 350z, Mitsubishi Lancer, Range Rover LR3
Update, I think it just doesn't clamp down enough comparing the factory soft top (1st pic) to the sunrider (2nd). The secondary seal on the inside barely contacts the top.
Nope, that was the solution, no CS needed.
Moving the strikers closed that small gap in the front of the top? I just installed mine and I’m dealing with wind noise entering
Gloff
Gloff
Sean
San Francisco
Two things helped:
1st: I pushed the entire assembly rearward as much as possible when tightening the mount bolts.
2nd: I moved the driver's side windshield header striker forward 1/8-1/4 inch. Your results may vary as there is significant space to move them around. Ultimately, the latch wasn't retracting the way it should, that's when I realized the striker was mispositioned relative to the soft top.
Hazard
Kevin
Two things helped:
Only the driver side? Passenger side did not need adjusting?
Thank you for the reply! I’ll try when I get a chance today. So the results did close that slight gap in the front where it meets the windshield?
Gloff
Gloff
Sean
San Francisco
Yes, in my case it was just the driver side. The way the Bestop latch is designed it gets tighter when you move the striker horizontally away from the latch
69BroncoX302
1969 U15, 2021 First Edition
Interesting, my bestop trektop is quieter then my hardtop was.
Dalbus
Derek
Dallas
Wildtrak Bronco, Jeep JK
I'm having the same issue on my Sunrider 4 door Wildtrak top. Its crazy loud and doesn't seem tight against the rubber gasket above the windshield.
