Unfortunately, a portion of the energy in gasoline is lost due to thermal losses. If you could recover the waste heat and turn it in to useful energy, it would make it much more efficient.Okay fine, but air/fuel ratio is necessarily measured as a ratio of masses because air density is highly variable, so the fuel specific energy is what really matters to the combustion process.
You did say energy density and not specific energy so you were technically correct on that count, but again, it's specific energy that makes the magic happen.
Yes diesel has longer hydrocarbon chains but those chains require more energy to be broken apart to take part in combustion so the net energy gain is lower.
I also think we should stop putting hydrophillic ethanol in our fuels.
