Merc4x4
steve
NJ
Did you remove the crash bars? :LOL:
sry, couldn't help myself. I always chuckle when I see that question in some of the threads around here... 😇
BigMeatsBronco
BigMeatsBronco
Allan
2021 FE 2 door
See I was just assuming you'd be on 54s by then.
Not yet, but I do have a set of 54s on beadlock aluminum wheels, but the bolt pattern is all wrong, (off the AMK31) that I thought about rolling under the bronco just to see what it would look like. If they weren't 300 lbs each i would have already...Could snap a few pics a get folks talking....😆 😂 😆
Tricky Dick
Dick
PNW
www.TD-Distributing.com
How did I guess? 😁
Mikey1287
22 Bronco, 72 Mach, 03 Mach, 69 Mach, 08 Harley
You're not worried about that tailgate?
Looks killer though...
Mudlight
Brent
F250
Boggers yes that is all you will hear on the highway
Awesome
Honestly, they are really quite. People have a misconception about these tires. I have run many sets of Boggers in the past. These are off-road only, I swap tires back and forth. I trailer this setup when going wheelin'.
BigMeatsBronco
BigMeatsBronco
Allan
2021 FE 2 door
Curious what these tires measure after they are mounted? Looks Great! I am on 38.5, with minimal lift.
Ford Bronco Bigger Meats.  2-Door Bronco Rolling on 40s 1678712264453
A little over 39" loaded sitting on the truck.
Your beadlocks look different than mine?
Mudlight
Brent
F250
These Boggers measure right at 38" with 30 psi in them off the vehicle. They do look different, I know there are various part numbers for the beadlock rings. These are M-1021-RA1, I purchased these individually on Ebay. It was alot cheaper.
Ford Bronco Bigger Meats.  2-Door Bronco Rolling on 40s 1678716959830
BigMeatsBronco
BigMeatsBronco
Allan
2021 FE 2 door
