5280Bronco
Denver
Is it normal to see shimmed dampers in automative applications? I would have expected the service life of the shims to be an issue given the velocity and frequency of compressions in a car or truck. I'm used to them on bikes, but surprised to see them here.
Anyone know how frequently these need to be rebuilt?
I have no idea on your first question, but i don't believe these bilstein units are rebuildable.
Silent Panda
SLC, Utah
2 door JL, a BMW Wagon and a bunch a motos
Using shims or deflecting discs in automotive dampers is the norm. There is a tremendous amount of work done to be sure the valve stacks meet the OE durability cycles. Sometimes the components are tested individually to 2x lifespan as stated in the OE's durability requirements.
The Bilstein dampers are built to survive the lifecycle of the vehicle without requiring a rebuild. I have no damn idea how some manufacturers get away with supplying an OE damper that requires a rebuild.
Hbates3
Hudson
Columbus, OH
2022 bronco badlands
I'm thinking about putting the 2" zone offroad leveling kit on my badlands bronco. It's a body lift, and I've read you shouldn't put a body lift on a vehicle you plan to take offroad. This is a 2" lift in the front, and 1" lift in the back. The manufacturer says this is designed for the bilstein shocks, and I don't plan on doing any extreme rock crawling. Since its such a small lift, do you think it would be okay to use for light offroading?
Werkedperformance
Werkedperformance
Philthy
www.instagram.com
Badlands 4dr 7MT
It’s not a body lift. It’s a suspension spacer lift, you must research more young Jedi. It makes the shocks effectively longer to lift the bronco
Werkedperformance
Werkedperformance
Philthy
www.instagram.com
Badlands 4dr 7MT
Am I able to purchase this particular suspension through Ford?
It’s the stock Sasquatch and badlands suspension. There’s a thread with the part numbers to order separately
Hbates3
Hudson
Columbus, OH
So is it a bad idea to elongate the front suspension 2" and the back suspension 1" on the bilsteins? Is something going to break if I take it off road with this lift? Also I've read about people having alignment issues, but not sure whet type of lift they are using.
ryartz
Rick
Ford F150
Ford dealer says that it’s normal for these shocks to leak and that ford has put out a service advisory for it. Does this look normal to you?? This Bronco Badlands SAS has 4700 miles on it? Dealer will not swap out the shocks..
Aonarch
North GA / MT
‘23 Bronco OBX 2DR Lux 2.7, ‘16 Corvette Z51
Ford Bronco BILSTEIN ESCV Bronco suspension / shocks explained - "End Stop Control Valve" Dampers (Bronco HOSS Suspension w/ Position Sensitive Dampers) IMG_2169
That is 100% leaking. Can you try a different dealer?
