- First Name
- Paul
- Joined
- Jul 27, 2020
- Threads
- 1
- Messages
- 642
- Reaction score
- 1,513
- Location
- California
- Vehicle(s)
- 4Runner
- Your Bronco Model
- Black Diamond
That video is going to give someone a seizure. They need to dampen the editing.
Looks like a relatively standard bypass style shock and they just added a cup and spring on either end of the shock for additional help. You have the hole that allows fluid to bleed into the reservoir as the shock compresses. Once the shock piston moves past that bleed hole, the shock will have significantly more resistance. Couple that with the cup and spring and I imagine that is what they are calling the “End Stop Control Valve”. Looks like the cup and spring are on the other end of the shock as well and will help with control on both the compression and rebound sides, but if I’m remembering correctly on how they are mounted (upside down), the compression side is where they have the most bottom our resistance.
King and Fox both make Internal Bypass shocks that work incredibly well. Both have the same function but just go about getting to the same result a different way. King uses a needle into the shock shaft and fox has a twin tube design. There are pros and cons to each one, but you can’t really go wrong with either. I prefer King, but plenty of people use Fox and both companies have trophy truck drivers winning races so I don’t know that one is “better” than the other.The question is, is it worth the jump up to Badlands from BD, or would an aftermarket install with suspension upgrade in the future work just as well?
How do you think I feel knowing the wife will be coming from her air-ride suspension in her GC and moving into the Bronco? She may have high expectations but thankfully she's driven my wrangler and truck.While I love the bottom out control for the 5% I will off-road, I'm really hoping the " soft in the middle" means the 95% of the time I use it for my Daily Driver it will have comfortable on road manners.
Okay, I admit it, I'm coming from an SUV, not a TRUCK, so I'm use to and still want a good daily driver. I know the forum is full of truck and jeep people that will say, WHAT, but this is why I did not buy a Jeep Wranger or a Ranger class pickup with I bought my SUV in 2017.
I think the Bronco will bring in many people, like me, as new owners who will also appreciate a comfortable daily driver.
Doesn’t Sasquatch include the trail turn thing and a few other “features”? If you can live without those, then no, that strategy I think is a smart one.This is great stuff - the initial video is a bit jerky, but the later comments tell the story - great forum.
I am thinking Black Diamond for economy, and pick up these shocks/springs as take-offs when people start lifting these on day one.
Can anyone see a problem with that discount strategy?
Oh god, don't start with the whole LiteBrite on the Bronco forums. Already see their stuff on the jeep forums lol.Some YouTubers recently toured around Bilstein's facility to give you a bit of an idea what modern manufacturing and quality assurance looks like.
I try not to get bothered by stuff but that video made me so angry... Not because of content but form. It is so jarring. LOL!!!That video is going to give someone a seizure. They need to dampen the editing.
That's a loaded question.The question is, is it worth the jump up to Badlands from BD, or would an aftermarket install with suspension upgrade in the future work just as well?
The Fox DSC kit for the Ranger is like $4000 if anyone is curious what the cost will be.King and Fox both make Internal Bypass shocks that work incredibly well. Both have the same function but just go about getting to the same result a different way. King uses a needle into the shock shaft and fox has a twin tube design. There are pros and cons to each one, but you can’t really go wrong with either. I prefer King, but plenty of people use Fox and both companies have trophy truck drivers winning races so I don’t know that one is “better” than the other.
Fox’s video is the best explanation of how an internal bypass shock works, and King’s video just shows you how they do what Fox does just without a sleeved shock.
Oh, and Fox then has the Dual Speed Compression adjusters (DSC). DSC is pretty dope, to be quite honest. Wish King had something like it.
King IBP:
Fox Internal Bypass:
Fox DSC:
I'm curious as well.
The Sasquatch is available on all trims and with it you get all of the cool off road stuff that is part and parcel with the two highest trims; Badlands and Wildtrak. With the exception of the sway bar disconnect and wheel tire combo on the BL (but it is available with a reduced SAS cost).Reservoir for extra fluid volume
Yea, the Fox and King internal bypass shocks are not cheap. They’re good, but it will be application dependent on if it makes sense to upgrade the existing Bilstein‘s to something different. I remember 3.0 shocks for the Raptor, without DSC, being somewhere around $5000 for Fox. if you wanted DSC it moved it closer to $6000 or so if I’m remembering right.That's a loaded question.
Application dependant.
T
LOL, I watched in on Youtube at 1/4 speed... Believe it or not, it is no better when it is slowed down.End stop control valve video. Can't find much on these dampers yet. Looks like a bottom out hydraulic cone and spring?
Anyone else have any thoughts. Someone said the ESCV was active but I'm not seeing it.
