Black Diamond 32's vs 33's. How much of a difference?
PowPow
PowPow
PA
2018 Tahoe
I went and saw a BD squatched and a BL not squatched, and honestly, couldn't tell the difference at all.
So I ended up walking away from the event thinking to myself, ya know what the 32's on the BD will probably be just fine. If the 33's don't look much different than the 35's, there shouldn't be much of of a difference between the 33's and 32's.
So I went home and crunch some numbers:
35's vs 33's
1.7 taller
1.2 wider
33's vs 32's
1.1 taller
.8 wider
The 35vs33 has a greater difference than 33vs32. And I saw zero difference between the 35's and the 33's... (maybe not totally true, from the front, they looked a bit wider. But from the side, they looked exactly the same.) The 33vs32 has even less of a difference size wise, so my thoughts are visually the 33's should be about the same as the 32's.
Wish my local event had a BD & BL non squatched to compare. But until then, math is all I got.
Rebel Bronc
Rob
Central NY
'22 Bronco 7spd Badlands
35's vs 33's
1.7 taller
1.2 wider
33's vs 32's
1.1 taller
.8 wider
Ok then...
Ford Bronco Black Diamond 32's vs 33's. How much of a difference? 9294EC29-29D3-426E-AECF-7596CEA0B459
PowPow
PowPow
PA
2018 Tahoe
Ok then...
huh? I'm not comparing 35's to 32's...
I'm just saying the 32's may not look much different compared to the 33's (BD next to a BL), if the 33's don't look any different than the 35's. BUT actually have a greater difference in size than the 33's compared to the 32's.
My reason for creating this post was because I wondered, will adding 33's to the BD really make that much of a difference visually? As I don't know, or haven't seen a BL sitting next to a BD.
I went to a local dealer event where there was a BL, non squatch, and a BD squatched. And I was just saying you could spin me around, swap the cars around, change the paint colors and by looking I couldn't tell you which was squatch and which wasn't... they look that similar (to me). So it got me thinking if they look so close to each other, maybe 33's and 32's look similar. and then I crunched the numbers and it's a bigger jump from 33's to 35's, so less of a jump from 32's to 33's to me, would say you'll see even less of a difference. And thus avoiding having to put 33's on the BD, if you're going just for looks...
BandofEskimoBrothers
Jay
Fort Mill, SC
I'm all in on a 2-Door BD. The General ATx is a really good tire, but I want something more aggressive and taller. Where as the 2-door looks decent with 32s, I think it will look perfect with 33s. If you're getting a 4 -door, I'd definitely up size the tires. I've done a lot reading on this forum and the general consensus is that LT285/70R17s (33x11.50) should fit without rubbing. Worst case, they would require removal of the front crash bars or aftermarket ones like these from ReadyLIFT.
As for tires. All the Bronco models come with either P (SL) or C load rated tires. Running E load tires will give a much harsher ride, even if you run them a little below the recommended pressure. The good news is there are a lot of great tires with a C load rating. There are also a few with a D load rating, which will probably still ride pretty good. I'll probably trade out my tires soon after I get my Bronco, so I've been looking at my options (a lot). I keep bouncing back and forth between LT255/75R17 and LT285/70R17s. Falken has a LT275/70R17 that's tempting. Here's a summary of the tires I'm considering. I included the stock tire for reference. Hopefully it helps.
Brand, ModelLoadSizeDiaWidthWheel
General Tire, A/TxCLT 265/70 R1731.6010.407-9
Wrangler, DuratracCLT 265/70 R1731.7010.707-8.5
BFG, KM3CLT 255/75 R1732.1010.006.5-8.5
BFGoodrich, KO2CLT 255/75 R1732.1010.006.5-8.5
Goodyear MTRCLT 255/75 R1732.3010.106.5-8.5
Cooper, STT ProCLT 255/75 R1731.8910.306.5-8.5
Cooper, S/T MAXXCLT 255/75 R1731.7710.206.5-8.5
Falken, Wildpeak M/TCLT 255/75 R1732.3010.206.5-8.5
General Tire, Grabber X3CLT 255/75 R1732.1010.006.5-8.5
Geolander, M/T G003CLT 255/75 R1732.3010.006.5-8.5
Nitto, Trail Grappler (MT)CLT 255/75 R1732.1710.286.5-8.5
Falken, A/T3WCLT 275/70 R1732.4011.107-8.5
Nitto, Ridge GrapplerCLT 285/70 R1732.7611.507.5-9.5
Nitto, Trail Grappler (MT)CLT 285/70 R1732.9911.507.5-9.5
Falken, A/T3WCLT 285/70 R1732.8011.107.5-9
Falken, Wildpeak M/TCLT 285/70 R1732.8011.007.5-9
BFGoodrich KO2CLT 285/70 R1732.8011.57.5-9
Toyo Open Country A/T IIICLT 285/70 R1732.8011.507.5-9.5
Toyo Open Country M/TCLT 285/70 R1733.0011.507.5-9.5
Goodyear MTRCLT 285/70 R1733.0011.507.5-9
Goodyear DuratrakCLT 285/70 R1733.0011.507.5-9
Goodyear DuratrakDLT 285/70 R1733.0011.507.5-9
Goodyear MTRD33x10.50 R1733.0010.57.0-9
General Tire, A/TxD33x12.5 R1733.0012.58.5-11
Ive got those 285 Falken Wildpeaks on my truck. They are great!
MoabRox
Two Jeep XJs, Dodge M880, Suburban 2500
I was leaning that way until Mickey Thompson came out with the Baja Boss A/T. That's the tire I'll be going with in a 33x12.50R17LT (D load)!
PowPow
PowPow
PA
2018 Tahoe
yes, these Mickey Thompson Baja Boss A/T seem to be making quite the splash...
dgorsett
colorado
F250, Mustang, Explorer
UPDATE: I have to walk back my comment about “E load” tires giving a much harsher ride. Just last week I talked with my local tire/repair shop owner about this very thing. He told me that if you run E rated tires at lower pressures (30-35 psi) there isn’t much of a difference in ride quality. That opens up a lot more options. I’ll probably still go with a C or D rated tire. I love Mickey Thompson’s new Baja Boss A/T, but I’m not sure that the 33x12.50s will fit a stock BD.
I usually run E's on my 4x4's, very reliable and I run 35 ish pounds. I don't notice ride issues. I agree with your tire guy. I run around door sticker pressure, if I'm running a significantly larger than stock tire I might run a bit less. Pressure printed on the tire is maximum, not recommended.
BD Cactus
Paul
BMW
Will these fit on the upgrade rims??
MoabRox
The minimum recommended wheel width is 8.5”. The upgraded Ford wheels (Gloss Black Aluminum) for the BD are 7.5” ( 8” at the most). I have not been able to verify that for sure, but the BL wheels are 17x8 and the Sas wheels are 17x8.5, so it makes sense that they’d be either 7.5 or 8.
Rather than add the optional wheels to my BD, I bought 5 Alpha Delta wheels (17x8.5, +35mm offset) for about the same price which will work with the 33x12.50s. The only question is whether or not I’ll need a minor front lift to clear the tires.
bigjwalt
Center Valley, PA
Mercedes E350
35's vs 33's
1.7 taller
1.2 wider
33's vs 32's
1.1 taller
.8 wider
I started in the same boat and saw those configurations in person and next to each other (in Doylestown and Nazareth). I walked away thinking the 32" would "probably be just fine." Then I got back to my principles.....I liked the look of the SAS and I refuse to give it up. Don't put yourself in the position where 6 months down the road a SAS rolls up next to you and you think "I should have got that."
MoabRox
Just looked on amazon... $320+ each for the 285s.... ouch.
You must have been looking at either the M/Ts or the A/Ts in R18. Summit, 4WP and others have the 33x12.50R17LTs listed for $275.30. More than the average LT285/70R17, but hopefully worth it. I’m not sure if I’ll get them right away. I may wait and see what the other manufacturers do to “catch up”, like Cooper’s new Discoverer Rugged Trek.
PowPow
PowPow
PA
2018 Tahoe
I was at the Doylestown event too 😁.
And no need to worry about that. I want nothing to do with sasquatch. Just not my thing. So that's not a concern for me.
I do like how the 33's look, which is why I started this thread. They're not as much "look at me", but still fill things out nicely and have a bit more presence to them, but not (again) "look at me" big. And don't get me wrong, to each their own. I'm not judging on anyone. Like I said, just not my thing. I won't be doing any heavy offroading, so I'd only be buying it for looks. Which some people will, and that's totally cool, no judgement.
So why I started this thread is because I really wondered how different will the 32's look on the BD (what I'm getting) vs throwing on 33's. Esp when the numbers aren't all that different. Then seeing the 35's and 33's next to each other, and seeing pretty much zero difference, it got me thinking 32's and 33's probably won't have much visual difference either. Hard to tell from photos, so I'd love to see a BL next to a nonSAS BD.
Or after someone gets their nonSAS BD and upgrades to 33's, I'd love to see a before/after shot. I'm just thinking, visually, it won't be much different. 🤷‍♂️
85_Ranger4x4
Iowa
1985 Ford Ranger
I have Grabbers on my Ranger and I really like them. As good as my old MT's on the trail and FAR superior in snow.
I plan on running the Grabbers on our BD until they are spent.
With the mileage ratings being released and the BD apparently taking a big hit compared to trucks with higher gearing the thought of going to a 33 with roughly the same width to maybe get the RPM's down a tad on the highway has crossed my mind. Dunno what the future of tires holds but right now I would go with Grabbers again.
I have Wildpeak AT3's on my F-150 which I would consider pretty equal to my Grabbers. Not sure I would go Wildpeaks again, I do like the looks of the Grabbers better.
I don't think the 32 really looks all that bad. Looks "normal" like it has mud clearance/room for articulation. 🤷‍♂️
Ford Bronco Black Diamond 32's vs 33's. How much of a difference? d-ba82e57e-3abd-4301-867e-3ada4847d89d_1_105_c-
Ford Bronco Black Diamond 32's vs 33's. How much of a difference? iconic-silver-bronco-black-diamond-
Broncodave
Seattle
Dodge Challenger/Nissan Xterra
So I have a question for this thread.
My conundrum is that I want the high package, but I am also in love with the less aggressive look of the black steelies and the Grabbers. So I'm thinking about buying a Badlands and putting on the Black Diamond wheels and tires instead.
If wanted to be true to the Badlands and get 33" tires, could I put a 285/70/17 on the steelies? They are a half inch skinnier than the Badlands wheels. 7.5" vs. 8".
