- Thread starter
- #91
I went and saw a BD squatched and a BL not squatched, and honestly, couldn't tell the difference at all.
So I ended up walking away from the event thinking to myself, ya know what the 32's on the BD will probably be just fine. If the 33's don't look much different than the 35's, there shouldn't be much of of a difference between the 33's and 32's.
So I went home and crunch some numbers:
35's vs 33's
1.7 taller
1.2 wider
33's vs 32's
1.1 taller
.8 wider
The 35vs33 has a greater difference than 33vs32. And I saw zero difference between the 35's and the 33's... (maybe not totally true, from the front, they looked a bit wider. But from the side, they looked exactly the same.) The 33vs32 has even less of a difference size wise, so my thoughts are visually the 33's should be about the same as the 32's.
Wish my local event had a BD & BL non squatched to compare. But until then, math is all I got.
35's vs 33's
1.7 taller
1.2 wider
33's vs 32's
1.1 taller
.8 wider
