Black Diamond axles same as Badlands and Sasquatch? How is 4.46 gears for Base + 35's ?
Bronco-Israel
Israel
4x4
Hello, does black diamond, badlands and Sasquatch have the same axles?
And how bad is it to put 35 on base manual 2.3 with 4.46, instead of the 4.7?
Cheshire
Steven
FL
4Dr Bronco BaseSquatch 2.7L
No, Badlands and Sasquatch have the upgraded Dana 210 front axels, Black Diamond has standard 190 fronts. Many have said that putting 35s on the 190s could create too much stress and cause problems. Depends on your use scenarios.
Bronco-Israel
Israel
4x4
Thanks
Nybadlands22
NY
2022 badlands, 2013 Shelby, 1965 fastback
Does the 4.7 automatically come on the Sasquatch?
Mikesmallcrawler21
TN
14 F150 screw
If that's the case, there is going to be a lot of broke, damaged front axles.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
A lot of pavement princess Jeeps running around on 35’s and Dana 30 3.73’s up front. Of course those are solid axles, but I figure we’re talking about the gears here.
Rahkmalla
15 K900
Does the black diamond with the 4A transfer case still have the 190 up front? thought all front lockers were 210s
noliveaxle
john
Riverside, Calif
2015 jku rubicon
Yes. The 4 auto does not add front lockers. Only the Sasquatch package will do that to the black diamond.
Rayder
Brighton,MI
F-150
A lot of them have severe amounts of premature wear because of it. When I was looking for a used TJ every single one with aftermarket wheel/tire setups had worn out front ends.
Frankie945
Frank
Louisville KY
Q50
If you get the m190 front just don’t lock it and it’ll probably be fine with 35s
Garemlin
Delaware
There were people putting 35s on JKs with 3.21 gears.
Rahkmalla
15 K900
Description for "Advanced 4x4 with Automatic On-Demand Engagement" on the Ford B&P
This system utilizes an all-new electronically controlled, on-demand two-speed transfer case and offers the driver four modes plus Neutral. When in 4A, it continuously varies power to the front wheels for optimum performance for all off-road conditions, provides electronically locked power to both axles in challenging conditions, and can also increase wheel torque for driving over challenging conditions. Flat towing is possible by putting the transfer case into the neutral position.
So are you telling me the 4A transfer case can only lock the front axle in 4A, but can't be controlled via hero switch?
Spooled
Republic of Texas
Ford lets you have 37's with 4.10's on the Raptor F-150. You'll be fine.
BlueBronco
DFW
'16 F150 KR - '21 BL - 23' OBX
Hero switches don't control 4x. They are for lockers, disco, tta and hazards. That description you posted poorly used the word locked when describing the four wheel drive system and reads like it was meant to describe 4L and 4H provide continuous "locked" power to both axles while 4A provides "as needed" power to the front.
