Black Diamond or Badlands
MudHorse
Rod
Detroit, MI
66 Mustang Convertible, 2012 Audi Q7
I am new to the forums and am sure this has been discussed. But I am trying to decide between a BD SAS or a Badlands SAS. I am from the Great Lakes area so not alot of rock climbing to be done here but I hope to make some treks west over the years. Is the sway bar disconnect really only an advantage on the rocks? Other than the Sway bar disconnect, Is there really much difference in the two vehicles? Budget is important, but I am always guilty of "over buying" my trucks with the intention of keeping them forever. (Hasn't happened yet, lol) Any help would be appreciated.
BruckinFonco
Hoboken, NJ
2017 VW GTI Sport MT, 1993 VW Corrado VR6 MT
I think the big different between the two, if you're going SAS on both, is going to be access to the higher level options packages. BD stops at the Mid package, so if you want the 12" screen, 360° cameras, additional safety interventions, etc., you'll need to go BL. If the Mid package or less is enough, BD would probably be more than adequate. BL also comes with the signature lighting, BD doesn't and I don't believe it's even an option, not sure if that's important to you.
I just checked price difference in B&P configurator: BD SAS starts at $45,075, BL SAS starts at $48,325. For the extra $3250, I'd personally go with the BL. Resell will very likely be higher and you do get some nice extra stuff for the price difference.
GToddC5
Todd
South Jersey
www.bronco6g.com
BD tops out at the MID package - Are you OK with that?
jay-rod427
Jerod
KS
Carbonized gray 2 dr BadLands Sans-Squatch ordered
Sway bar disconnect not a deal breaker if you don't plan on using it regularly, and yes it's primary use is rock crawling. If you ever get to rock crawling someday you can just manually disconnect it.
As mentioned otherwise the BL is just more options, and MGV interior with the washout floors.
BruckinFonco
Hoboken, NJ
BD and BL both have MGV and washout floors.
flatlander40
Honestly, it’s your decision. Depends on how you prioritize the features, extra storage, budget, etc.
I wanted the features of the BL and compromised on some other things to get there.
Drex
Jake
You cannot get the High Package which means no fancy 360 degree camera action.
BruckinFonco
Hoboken, NJ
I forgot to ask, are you doing two-door or four-door? I based my answers and pricing on the two-door models.
chowfun27
IA
Jeep Wrangler 392
I was in a similar conundrum between BD SAS and BL w/o SAS and landed on a BL SAS :LOL:
For me, it was a $2k difference between a BD SAS Mid package and BL w/o SAS High package. I just felt the additional features of the BL was worth it. Then I realized I know I would regret not getting SAS so ended up with BL SAS. It was about a $4.5k difference between BD SAS and BL SAS for me and truthfully, I feel like the BL w/o SAS is a better "value" but I'm happy with my decision.
BL SAS over BD SAS gains you....
-Sway bar disconnect
-Signature lighting
-Different grille
-Black MGV with orange accents vs Grey/Black MGV with blue accents
-Baja GOAT mode vs Sport on BD
-Option to get High/Lux/Leather
Look at the price difference between the 2 and ask yourself if it's worth it for these items! Only you can answer this question.
webspoke
Stan
Pilot Point, TX
F450, GT350
Just went through this decision. If you do not get SAS, then Black Diamond has the base suspension without bilsteins, only rear locker, badlands has f/r lockers.
If you want the 4cyl + 7spd manual, then Black Diamond only gets 4.46 gears instead of 4.7 on the badlands.
If you get SAS, all of those options become the same between the two.
FilmcoBronci
Wes
CentralTime
Bronco 6G
If you’re contemplating doing SAS in both, I would get the BL. We have a ‘21 BD non sas with 33’s and go between Midwest and Rockies for work. When we get to work, we are In 4 wheel 80% of the time in Mtns on trails and mining roads, and are undefeated, BUT, we don’t do crazy rock crawling so we’re fine. Rinse and repeat.
We went BD NonSas because of 4:4:6 and lots of hwy between. We knew we were keeping it and driving the dirty hell out of it between flatland and Rockies, Resale or flipping was not a realistic consideration We have 60k mikes on it, modify something every 6 Months, and are filthy with joy.
There is little in Midwest that needs sway bar disconnect, but get the B/L-SAS if resale or future extreme off-rocks are determining factors. Best OEM bargain in off-road.
Mid package, MGV and Small Screen were fine for us but 360 trail cam is impressive . test drive them both.
