Black Diamond Sound Deadening Dilemma
BroncoBuckaroo
Joe
Missouri
2017GT350-SOLD, 2013 Ford Edge, 1969 Torino Cobra
Not if the majority of orders would now be “with” sound deadening, which do you think would be run first/most often, but I could be wrong, it’s just my guess!
this headliner is not part of the Ford assembly process, it’s part of the supplier process and there were not a lot of takers. I can see that if 1 out of 20 purchased the headliner it could slow them down because the supplier would have to dedicate 2 manufacturing lines, now it’s just one, but not adding the headliner doesn‘T create an extra step, just gets a different bar code. If you think about it, if adding a headliner is the case to make it a longer build, then a Badlands and Black Diamond would take longest ..those versions have special drain plugs, sway bar disconnect, bash plates etc that other Bronco’s don’t have. Honestly, I don’t think adding options in a particular run bother Ford productivity at all (as long as they have the parts) ..I think they base their runs on demand (model popularity), available production parts and in the case of the Bronco order time stamps. It looks like Badlands has the most initial orders followed by Wildtrack, and then pretty close between all other versions. But time will tell
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
I don’t see how the source would change anything and no, I didn’t say Ford produced the top and I’m under the impression that order rate is much higher than what you suggest, where are you getting your numbers?
Bronc-O
Phoenix
2021 Lincoln Aviator
it’s not card board -it’s panel board - In addition to foam, radiant backer and then colored material.
Perhaps, there's foam in there, but I'm doubting the hardboard you show is. That stuff is relatively heavy for it's size and soaks moisture like a sponge.
zfischer
New Mexico
F250, Tacoma, 4WD Sprinter, BJ42 Landcruiser
MGV interior here and would also prefer aftermarket. I would love to have confirmation from Ford that declining the headliner would not result in a delay.
RandyStewart
Mississippi
They're installing on all MIC Tops for Broncos that *don't* have the Marine Grade Vinyl.
Customers that DO have MGV need to contact their dealer to add the free deadener if they want it.
Possibly a small update here. I ordered a Badlands with MGV seats. Contacted the dealer today to request the sound deadening headliner be added. He came back and said it was already showing on my build (I did not have it at order time). So maybe they are just adding it to every MIC top no matter the interior.
BroncoBuckaroo
Joe
Missouri
get that extra $5 of commission - well How it was when it wasn’t free anyway
