The averages you are referring to are to his specific vehicle. Blackstone keeps track of them for you and updates that column each time you get an analysis on your vehicle.It says they have no data for than engine in a bronco - the averages are the same as the data set.
Fuel diluted oil is not uncommon in the first oil analysis, the rings aren’t set until the engine works some. If there is too much fuel in the next sample run conventional oil on the next oil change. Lots of short trips, idling or babying an engine can cause fuel dilution. Those rings need some heat and work to seat.
Your right. I had to zoom the image on my phone and got specific vehicle vs average of vehicle mixed up.The averages you are referring to are to his specific vehicle. Blackstone keeps track of them for you and updates that column each time you get an analysis on your vehicle.
They are the same because it's his units first analysis.
And for the people asking for a "high level interpretation", it's right there at the top of the report...
$30 and it took about 2 weeks.What is the cost/ analysis results timeframe on this?
Not bad at all.$30 and it took about 2 weeks.
I chose to wait until 2500 miles for our first oil change. I know a few on here were insisting on 1000. I split the difference so to speak.
Even though the dealer insisted 5000 would be fine and that I was wasting money - I was confident in wanting to see what this report revealed and provide info for the rest of the community to make their own decisions based on these results.
I used Ford Pass Points - which is weird because I gained 495 points at the same time.
Those of you with more experience - please chime in. I’ve used Blackstone in the past - but, it was for a TDI/Diesel engine and I was moderating metals due to camshaft wear
Breaking-in regime was:
Drove it as suggested by manufacturer. 1,000 went quickly. Lots of hilly backroads, some highway and to and from work - which is only a mile (down/up hill). Wondering if that has something to do with fuel in the oil.
I am pretty certain I kept it below 3500 RPMs (for the most part anyhow) and didn’t take it off-road until after the 1k.
Nope. PCV is Positive Crankcase Ventilation, has nothing to do with fuel. Emissions is engine management, catalytic converter, and the evap system in the gas tank. None of those have anything to do with a catch can.What I get from the commentary is that a catch can is a must. Fuel in the oil is from the emissions/pcv system.
The numbers on the "Elements in PPM" section show how much of each material was found in the oil. The far right column shows the averages that Blackstone has measured in other 2.3 EcoBoosts. The tech pointed out that the copper and silicon values were much higher than average - copper is found in bearings, silicon is introduced by poor air filtration, coolant leakage, or by dust/particles in the air making their way into an open engine while it's being worked on. Iron is usually cylinder walls, chromium is often the piston rings, and aluminum is usually piston material. If you look at what value is high, you can usually figure out what's wearing out. In this case, the copper was high due to initial bearing break-in, and silicon was high because it's a fresh build.What does the report conclude?
^^Fuel in the oil is from the rings not seating and the engine not getting hot enough to vaporize the fuel. A can isn’t going to do anything for either of those conditions.
If you do the 3000 mile change like they suggest, I'd say it's important to make sure the thing gets fully warmed up and sampled properly. No point in sending them another cold sample only to keep finding fuel in it.I’ll be sure to update this thread with the next report. It seems they are suggesting I do it at 5500 instead of my planned 7500. Stay tuned.
Which OEM do you work for? What test data are you basing this on?Meh, this soft break in recommendation isn't the best. The idea is to seat the rings, everything else doesn't really care. What seats rings? PRESSURE. The only way to achieve that is to load the engine and give it some RPMs - ala kinda beat on it.
