Blown fuse curt trailer wiring
fv9
Camas, WA
2018 Alfa Romeo Giulia Ti Sport, 2005 Lotus Elise, Protoform P3 formula vee, Crossle 32F formula ford
I installed the plug and play flat 4 trailer wiring last weekend. Plugged in a tester a day or two ago and no joy. Checked the red 10 amp fuse supplied at the battery and it’s blown. I can replace but is a 10 amp fuse sufficient?
ArrickSports
Tim
2011 Chevy HHR
If that is the fuse it came with I would say yes. I'm somewhat familiar with the testing procedures at Curt so I'm sure that is what they tested with. I don't know if that is like the Reese version where you run that power line along the underbody of the Bronco from the battery but if it is, more than likely the wire was pinched/kinked/nicked somewhere.
  • Like
Reactions: fv9
fv9
fv9
Camas, WA
I’ll trace it. Thanks.
fv9
fv9
Camas, WA
HBTFD
Newnan GA
F350
I would check your ground.
fv9
fv9
Camas, WA
I grounded it to the rear frame rail. Drilled the hole and used the self tapping screw. Still secure.
HBTFD
Newnan GA
F350
Did you sand off the area where the eyelet contacts the frame?
fv9
fv9
Camas, WA
No. Was lazy and presumed the screw was making contact with bare metal.
mini4mw
W
Atlanta
Tundra
Id put in a new fuse and see if it blows. If it doesn't, try blinker, check fuse, lights, check fuse, brakes check fuse (without a trailer). If that all works, then plug in a trailer and repeat to see when it blows.
Those fuses are cheap and maybe while installing you shorted by accident. Don't go retracing everything without trying it again.
You should sand it down. It should be fine at install, but longer term it won't be good enough. After you sand it down and re-install, hit it with some paint to prevent rust.
HBTFD
Newnan GA
F350
Sand a dime sized area around the hole and try another fuse.
  • Like
Reactions: fv9
zombie
New Brunswick, Canada
2021 Bronco Badlands (7spd) 2022 Mustang GT PP
I had the same issue the very first time I went to use my trailer lights, had to replace the fuse... haven't had any issues since.
SuperDave150
Albuquerque, NM
Ford F-150, Ford Edge
I say go up in multiples of 20 until you let all the smoke out.
That‘ll git ‘er done!
BTW, you do own a fire extinguisher, don’t you?
  • Haha
Reactions: fv9
SuperDave150
Albuquerque, NM
Ford Bronco Blown fuse curt trailer wiring 1662154628141
