Boost gauge change kPA to Psi
internationlriders
Josh
Alberta Canada
2021 Bronco Badlands
here in Canada we get our boost gauges in kPA which is super annoying and difficult to read. Does anyone know how to change the boost gauge to imperial Psi? I wonder if there is a way via Forscan without changing all gauges to imperial..
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
WHO THE F USES KPA FOR BOOST READINGS!?! It sure the hell isn’t us. The boost gauge is still a nice touch though.
BAR would be marginally better, but PSI is more common and preferred. I hope that @Ford Motor Company can provide this customization/option/feature in an OTA Update. It’s curious that you can change almost every other measurement unit, seems like it wouldn’t be too tough of an ask. Maybe also allowing us to truly customize the “My Menu” and select any arrangement of pages or gauges
James Cole
MX
Badlands Sasquatch (hopefully)
Any updates on this?
internationlriders
internationlriders
Josh
Alberta Canada
You can change measurement units in the infotainment general settings but then you also get switched to mpgs.
