Brakes issue - 2.3L BB 4DR
andyriegler
Andy
Muskegon
2022 Bronco
Annoyed.
New BB 4 door 2.3L with 2700 miles. I was driving on the highway cruise set at 75, and message pops up saying "check brake system", then brake light came on. I pushed the brake at 75MPH and it was rock hard - the brake pedal didn't move. It did slow the vehicle down, but pulsed as if ABS was engaged. Once I took my foot off the brake again, the brakes acted normal but the "brake" warning light stayed on.
I drove directly to the dealership and they have ordered a Vacuum Hose for the brakes. The part will be in tomorrow so driving a loner car until they can get it installed. I wonder if this is a known issue or if it's a one-off (lucky me!). I'll update on this thread as I learn more. Please reply if you have had the same issue.
Tornado_735
Aaron
Oregon
19 Silverado, 18 EcoSport 4x4, 09 Aveo, 1995 P38
It is a known issue.
Tornado_735
Aaron
Oregon
2021-2022 Bronco - 2.3L - Illuminated Brake Warning Lamp And/Or Brake System Warning Message – DTC P050F Set In The ABS Module And Firm Brake Pedal
Some 2021-2022 Bronco vehicles equipped with the 2.3L engine may exhibit a red brake warning lamp and/or brake system warning message in the instrument panel cluster (IPC) with a diagnostic trouble code (DTC) P050F in the anti-lock brake system (ABS) module and a firm brake pedal. This may be due to contamination in abrake booster vacuum line. To correct this condition, replace the vehicle's vacuum hose.
BlueBronco
DFW
I have had the same issue since I picked mine up in August. Only seems to happen on trips longer than 30 minutes and even then it is random. Dealer checked it out, listed the same SSM as above and surprise, surprise, the part was back ordered. It is an annoyance but not a safety concern where they dealer has to hold the vehicle. I will get it fixed eventually.
andyriegler
andyriegler
Andy
Muskegon
2022 Bronco
