Yeah, our tire and wheel came off with the axle in on piece.The TJ came with two rear axles, normal was a Dana 35 which was c-clip, and the Rubicon came with a D44, which is not c-clip. C-clip means the axle shaft is retained in the housing a c-clip at the end of the axle shaft, inside the carrier. Non c-clip, like a D44 or the M220 (since it's a derivative of the D44) has a retainer plate on the outside at the end of the housing. Break a c-clip axle and it will slide out, unless it has disc brakes then the caliper will try to hold it in. The M220 should be non c-clip, plus we have disc brakes. Should be pretty hard to break that 32 spline axle unless we run bigger tires, bounce it and get unlucky.
