Bronco (2.7 engine) shut off on highway, left me on the side of the road
N0madK1ng
Anthony
SoCal
Subaru wrx
MB3E-6007-AA is the part number you would use to order the complete engine (other part numbers are compatible MB3Z-6006-A, MB3Z-6007-A, MB3Z-6007-B, etc).
I think you missed a digit. 21159 (June 8th) 120217 would put you right in the middle of the sequence. So 3,500 miles has been the high cutoff so far. Glad it's running great!
Hmm interesting. Yeah would be nice to know from ford the problem build dates. Here is the full number. EF06A 21159 120217. So that puts me smack in the middle of the known problem engine build dates? Forgive my stupidity on the matter lol
mpeugeot
The date your engine was built is the day before the earliest known failure.
June 9th - July 28th
The sequence number is in the middle of the known failure sequence numbers.
120068 - 120300
It's unclear whether this is going to track by date, by sequence number, or both. It may not even track at all, that's why the effort to track it.
N0madK1ng
Anthony
SoCal
Subaru wrx
O
120068 - 120300
Ok I understand. Well I’ll try to be optimistic lol. Thanks for the explanation.
straycat
Matt
St. Louis, MO
2011 Toyota Camry, 2021 Ford Bronco
Great, now I have to go find my engine number...so far running great at 1000 miles, but don't want to take her on a long trip if I'm in the middle of that group.
mpeugeot
0. No Serial Number - FAILED
1. #EF06A21160120068 MB3E 6007 AA FAILED
2. #EF06A21180120249 MB3E 6007 AA NOT DELIVERED
3. #EF06A21161120300 MB3E 6007 AA FAILED
4. #Unknown FAILED
5. #EF06A21166120417 FAILED MB3E-6007-AA
#0 mmcq's No date
#1 Broncoshrimp's 2021 160st day; June 9th.
#2 mpeugeot's 2021, 180th day; June 29th.
#3 69 Mach I's 2021 161st day; June 10th.
#4 estone's 2021 209th day; July 28th.
#5 nikole's 2021 166th day; June 15th.
straycat
Matt
St. Louis, MO
Mine is EF06A21175131382 - which I assume is June 24th....right dab in the middle of the failing engines. Awesome.
N0madK1ng
Anthony
SoCal
Subaru wrx
Yeah man kinda shitty to think about but as others have said, the probability, based on known failures, should be very low and should not effect your drive distance. Siiiiigh
mpeugeot
But the sequence number is way outside the range. I would rather be in your position than mine.
120068-120400 vs 131382 (almost 11,000 units away)
or Dead Man Walking below...
120068-120400 vs 120249 (less than 150 units away from 2 known bad units)
N0madK1ng
Anthony
SoCal
Subaru wrx
I think you mentioned my sequence number is in the middle of the failed ranges. Maybe the other guys sequence number is outside the low and high range
mpeugeot
Once again, I am not sure if it is date related or sequence related, but mine is both within the date range and the sequence range. Practically guaranteed to blow up.
N0madK1ng
Anthony
SoCal
Subaru wrx
damn man well I hope mine, yours and everybody else's will be ok moving forward lol. Even the auto stop/start scares the shit out of me randomly because this is the first vehicle I have owned that has that feature.
5280Bronco
Denver
At this point, the first thing I'm going to do when i get mine on Friday is look at the engine info to see where it lands on this whole sequence. It was built July 15th, so I'm guessing it has a motor from that timeframe in it. Good times.
icd70
Robert
Indiana
OK tin foil hat time.... Ford knew that the engines where bad, created the hard top issue to put them on the DM to avoid a rash of engines blowing up early in the release and all at once? ok maybe not but I'm sure 5G gave me a rash... LOL
mpeugeot
I wish, but seriously, I don't even know if they are sure what the root cause is at this point. If they didn't know what the root cause was, and they said,
"We're collecting data on this, currently we have a handful of motors with a similar failure but no definitive cause. The motors we're currently investigating were built with dates between X and Y with motor sequence numbers from A to B. Should you have a similar problem, please have your dealer contact their Zone representative so that we can get an engineer involved early in the process."
That would satisfy my concerns... end it with:
"At this time we don't believe that motors between these date ranges and sequence numbers are likely to experience a failure; given that 99.72% engines have not experienced a failure of any kind. Until there is evidence that a significant number of engines are demonstrating this problem, it would be pre-mature to issue a recall or TSB at this time."
This is SO F'ing simple... It's called communicating!!!
BigSkyBadlander
Cole
Montana
'06 Honda Element 2023 Bronco Badlands
Cha cha cha… yes, once upon a time…
Yes, but they take the tech and sell the company off. Not the best situation for the companies after the fact.
