Bronco (2.7 engine) shut off on highway, left me on the side of the road
69 Mach I
69 Mach I
Sean
'15 F-150, '87 Mustang
Vehicle Showcase
Cant look at stickers unfortunately right now it was towed to dealer and only car so I have deal with Ford about a rental car ASAP as soon as I can
Get that I can see about going over to dealer and take pictures to post of stickers. All I know now the car started build on 9/6 of course that has nothing to do with engine build date except it was before date date
Ford should take care of rental car. I was told they will reimburse me after Bronco is repaired...just have to submit receipts. The dealer may also have a loaner car they will let you use while Bronco being fixed.
Advertisement
unfortunate
NA
So my bronco was starting build 9/7 and this afternoon the engine when into complete failure. I have about 4,000 miles on it mostly road but several 4-6 hr off road runs and one oil change. It all of a sudden made noise that sounded like the entire engine was coming apart and then started sputtering and then the engine light came on and a message oil getting low stop engine. Then mass smoke started bellowing from undernight and it dies get it off road and oil was flowing out from multiple areas under the engine. Towed to dealer I am positive a valve or something blow and went through the bottom of the engine and killed it. So guess I am now in one of the failed 2.7 cases. It was working fine until this unexpected thing all of a sudden. I had no issues nor indications of issue before within the 4,000 milesw
can you post you vin or send it to @mpeugeot he has some way to get the build date of the engine from the vin. Do you run premium or regular?
unfortunate
NA
Mostly regular but that in my opinion has nothing to do with the issue
yeah… Ford has been pretty tight lipped about the 2.7 problem. I’m just thinking of the possibility of detonation/pre-ignition due to the lower octane causing the engine timing to be off and the piston to crash into the valve breaking it. Technically Ford designed it to use regular gas as well but you never know….
69 Mach I
69 Mach I
Sean
Vehicle Showcase
I imagine they will attempt to remain tight lipped until somebody gets hurt.....or worse.
1941
Emil
New Orleans, LA
2020 Jeep Wrangler
im sure that’s part..interestingly, searching the F150 forums show zero problems with the 2.7 engines and there are way more of these in F150’s presently rolling down the line than Bronco s
The F150's have a different 2.7 than the Bronco.
mpeugeot
97 Ferrari F355, 11 Ford F-150, 06 Suzuki SV1000s
If you haven't already, please add your info to the engine tracking thread. Sorry this happened to you! @Ford Motor Company will be along soon to open a trouble ticket for you.
Bubbabow
Hendersonville NC
Here is final from dealer the engine is “catastrophically destroyed” all fluids blended together and such implosion it blow the oil pan plug out of the pan. So new engine but Ford is covering car rental until fixed. Question how do you tell engine production date from t thing on engine?
Bubbabow
Hendersonville NC
However very pleased with Fords
response very helpful and responsible I have no issues at all things happen they are taking care of all issues that need to be done
Dragline
GMC Yukon Denali, GMC Sierra 1500, Honda Civic, Chevy C3500
@Bubbabow Long number at the bottom, after EF06A the 21228 is the year '21' and the day #228, or August 16.
mpeugeot
If you can't find it, you could ask @flip to look it up for you, he would need your VIN to do that. That's who I ask (mostly) when I need an engine serial number looked up, but I have other people I can ask if necessary. @flip is a stand-up guy!
69 Mach I
69 Mach I
Sean
Vehicle Showcase
Ford customer service has been extremely helpful with me. They actually called yesterday....dealership said mine would be ready next week. I'm hoping dealership will tell me exactly what they found when I pick it up. I just hope there aren't any scratches, scuffs, grease spots, or dings and they get the hood aligned correctly.
Bubbabow
Hendersonville NC
Thanks so far they have been great I do like my bronco stuff just happens but they are working hard to correct
mpeugeot
Seriously, I hope it's perfect, but mine was so caked in dirt, that I don't want to get anyone's expectations up. That said, mine could be much worse... it only seems like the top is leaking a little so far.
TXscooterguy
Dennis
Bedford, TX
2017 Honda CR-V
Brand new 2.7 drops valve and blows up, driver/owner has heart attack, wife /hubby misses partner commits suicide, kids have to go to foster care, get hooked on opioids, after all is said and done bronco is covered under warranty.
Holy crap, Batman! I was talking with my neighbor a few days ago and told him how I had just ordered a Bronco with the 2.7 motor. I need to print this post out and give him a copy. Should this cruel fate befall me, I'm going to ask him to be on the lookout for any signs that I may be succumbing to this stressful event. Maybe I should pre-sign consent for a voluntary psych hold.
Advertisement
Advertisement
