Bronco AUX amperage for lights
Jdimaggio
Joe
Northport, NY
Hi so when connecting the wires to the AUX wires which ones would these be good for. I have two of the 3” LED lights and one LED pod. Does it matter which wire it goes to?
geoking
george
Huntsville,AL
2020 GT500 , 2020 F150, 1934, 1948, 1958 , 1966
sport or pro? ad up the total amp draw and connect to the aux switch with enough amps to cover it
Jdimaggio
Jdimaggio
Joe
Northport, NY
They are sports, the pair of lights would all be going to separate wires
Jdimaggio
Jdimaggio
Joe
Northport, NY
So basically it’s would be 2.2 A, 2.2A, and 1.2 A. If I’m doing it right. So with that I would be able to connect it to any wire.
IDyeti
SPAM
Boise, Idaho
21 Bronco BD
Any, but applicably aux 3, 4, 5 or 6. They are all 10amp circuits. Don't waste your aux 1 and aux 2 on this.
  • Like
Reactions: Cat
Jdimaggio
Jdimaggio
Joe
Northport, NY
What I was thinking, just wanted to make sure before doing any wiring. Thank you
Perfect-Beast-2
Rick
Virginia and NJ
1973 F100 / 1980 F150 Stepside / 2019 F150 Lariat
I’m having real difficulty understanding how to connect to the different switches. Dealer installed light bar on AUX 1, mirror mounted lights on AUX 2, and wheel well lights on AUX 3. Id like to wire to any of the others for a decorative light on the grill. I found the wire (sort of lavender with a gray stripe) at the grill area. That goes back to area near the fuse box. It’s not preconnected to power. How do I connect to switch box to power it? Onboard manual is sketchy at best and only YouTube video I found isn’t much help either.
Dragline
GMC Yukon Denali, GMC Sierra 1500, Honda Civic, Chevy C3500
Connect the switch you want running it to the wire going to the grille.
Ford Bronco Bronco AUX amperage for lights Screenshot_20211114-230405_Adobe Acrobat
geoking
george
Huntsville,AL
Here's a tutorial to help you.
https://www.bronco6g.com/forum/thre...liary-switches-on-the-2021-ford-bronco.23539/
  • Like
Reactions: Cat
