dgorsett
colorado
F250, Mustang, Explorer
I have an awning on my motorhome and seldom use it. As can be seen in three out of four pics in this thread, there is little chance it will be oriented properly for shade . And a high chance the wind will reek havoc with it.
mvilla
San Francisco
4-door Badlands Bronco w/ Sasquatch package
OVS Nomadic 270LTE from Amazon. Not saying it's the best but suits my needs, budget, and weight. One camping trip in the rain made me get one, $450 and 35lbs. Option for driver or passenger side. Not easy to install, I purchased more mounting brackets for stability. Mounted it to the frame of my FSR Aspen Lite RTT. Easy to deploy and put away by myself. I installed some battery powered strip led's underneath for lighting. Deploying the legs aren't necessary as it stays up by itself. I need to figure out a better way to put it on/off before the spring.
Can I see how you attached it to the aspen lite?
dejones64
Dan
MN
Bronco 2-dr Black Diamond
My FSR is in storage for the winter, I'll see if I can get some pics...
hec1
Hector
2022 F150 37PP Raptor 2024 Shelter Green Raptor
I’ve been considering a moonshade. Glad to hear this cheapo version gets the job done.
i have one for sale soon. Moonshade. If mentioning that isn’t allowed i apologize
Will post in camping section when ready
prospectfour
Pete
NJ
'22 Bronco, '18 Tiguan
Migo
Roy
Houston, TX
www.instagram.com
I
Digging the simplicity of that, do you have a photo of it closed? i want to gauge how high the awning sticks up above the trailrax, i have chase lights on that last load bar that i don't want to cover up.
Here is a side and rear angle shot. I used the included L shaped mounting brackets with the short side of the L facing down, to get it as low as possible.
Ford Bronco Bronco Awning Showdown! ⛺️ What Are Running And Why Do You Think Yours Is The Best? IMG_0578
Ford Bronco Bronco Awning Showdown! ⛺️ What Are Running And Why Do You Think Yours Is The Best? IMG_2014
BigHank21
Henry
La Mirada, CA
2022 Bronco, 2023 Maverick
I have the OVS HD Nomadic 270 Awning. I went with them because they’re a local business and I like supporting local. The awning itself and mounting brackets are super solid. I have zero complaints. I also added 4 Diode Dynamics RGBW LED strip lights (50cm) on a Bluetooth controller to it.
Ford Bronco Bronco Awning Showdown! ⛺️ What Are Running And Why Do You Think Yours Is The Best? IMG_6786
Ford Bronco Bronco Awning Showdown! ⛺️ What Are Running And Why Do You Think Yours Is The Best? IMG_6793
Ford Bronco Bronco Awning Showdown! ⛺️ What Are Running And Why Do You Think Yours Is The Best? IMG_6808
Ford Bronco Bronco Awning Showdown! ⛺️ What Are Running And Why Do You Think Yours Is The Best? IMG_6806
hec1
Hector
How do the 270 freestanding do in 15+ winds?
RustysBronco
RustysBronco
Matt "Rusty" R.
Jupiter, FL
www.instagram.com
2022 Ford Bronco Badlands Sasquatch
That looks like it has a ton of coverage area.
GroovyGeek
Boyan
'23 Bronco BD
Mine is far and away the best for my needs. 9x6 Mesh tarp from HF, two cheap poles, 4 cheap stakes, 4 DYI guylines, two marine suction cups. Collapses to the size of a 2L bottle. Let's wind pass through. Zero impact to gas mileage . Sets up and tears down in a jiffy. Under $50 all in.
Ozzy
Cornelius, NC
Here is the soft top solution
I just installed on my Bronco... It is awesome!
X-Rack
**Stay Topless in Style with Our New Side Rail Rack for 2021+ Ford Broncos!**
Our new Side Rail Rack bolts on seamlessly under your soft top, letting you open and close it without hassle – no drilling required!
Perfect for mounting privacy enclosures, shower setups, shovels, axes, traction boards, and even awnings with ground supports (up to 30lbs). Add one to each side and maximize your accessory capacity.
Includes a Side Rail for one side + 2 accessory brackets.
Shipping starts 10/31/2024!
Upgrade your adventure
https://www.xrack.us/.../side-rail-for-2021-ford-bronco.../
#FordBronco #AdventureReady #OffRoadAccessories #StayTopless #Xrack #BroncoNation #fordbroncos #broncolife #XrackUS #fordbronco
I assume that rain gutters would have to be removed to run one of these?
BroncoA512021
Long Island, NY
www.facebook.com
2021 Ford Bronco OBX
I don't have rain gutters. Maybe....
Noremac
Arkansas
2021 Bronco Badlands Sasquatch
I picked up a second-hand free spirit recreation 270.. While "Best" is hard to quantify, I was a bit picky. I wanted something free-standing and not needing to use support poles in anything but serious wind, and a wall kit.. I picked the awning and wall kit up for $500
Ford Bronco Bronco Awning Showdown! ⛺️ What Are Running And Why Do You Think Yours Is The Best? 1730812415216-fc
Ford Bronco Bronco Awning Showdown! ⛺️ What Are Running And Why Do You Think Yours Is The Best? 1730812398598-2r
