FifthCard
Allen
US
Jeep Wrangler Rubicon
Jhuff
J
Toyota Tacoma and DR650
I need some input. In the beginning of all this, I knew the models and specs well, but now it is all a blur.
I am getting a manual badlands, no matter what, but was waiting for mansquatch.
If I forgo squatch and go ahead and order a manual badlands, then install this (or a similar kit), would I be losing anything? I don't think so, but there is a ton of information to go through.
rmanecke
Ryan
83CJ / 87YJ Mashup
The other way to get the 4.7 gear ratio is on the 2.3 with the 7 speed manual BL - am I wrong?
mull.jm
Jonathan
Bethlehem, PA
2019 X7, 2016 X3, 2021 Bronco Badlands (On Order)
Never mind. I figured it out.
Blk Diamond Cheese/2D/2.7/SASQ/MIC/MID/TOW
Would love to know what/where to get these rims. Could you please pass along this info?
Diode Dynamics
John C.
St. Louis, Missouri
www.diodedynamics.com
Ford Bronco
Pkrpro19
Jaxon
Panama City Beach
BMW X5 M Sport, Mercedes Benz E350, Bronco Raptor
So it was a factory sasquatch, and got all that yanked out and replaced with a 4" lift that would be 4" on a base? Assuming all new coilovers all around?
No… the upper control arm was changed and 2” spacers added to give an overall 4” lift.
Pkrpro19
Jaxon
Panama City Beach
My question is more about the lift height comparison. It was a Sasquatch, but if it's a "4" lift that 4 inches is over a base, not Sasquatch+4".
No… they changed the upper control arms to a bds control arm and added 2” spacers. The Sasquatch is already a 2” lift from factory, so this makes it a total of 4” using the factory suspension.
rtaylor
R
ID
19Raptor, 22Bronco
Note that sasquatch is 1.1" lift compared to base (not 2"). The kit includes a combination of strut spacers, preload collars, and bump stop spacers that are used to reconfigure the factory coilovers.
Details from kit instructions:
Ford Bronco Bronco Badlands Sasquatch on 37’s + Maxlider Brothers 4” lift kit 1632374537021
Also see newer thread:
https://www.bronco6g.com/forum/threads/4”-maxliderbros-stage-1-lift-kit-available.23826/post-847044
Compta38
Alabama
Ford Fusion
That's my trim, my color and my stripe.
Bird Dog Off Road
Jody
Chicago, IL
www.youtube.com
No, you can get it with the Sasquatch package with the 35s
Nybadlands22
NY
2022 badlands, 2013 Shelby, 1965 fastback
We haven’t gotten to do that specific test on that specific setup yet but I would be slightly nervous. If you don’t do SAS, what will you do for fender flares to get coverage? These tires SHRED the side of your Bronco with shrapnel!
Would adding sas flares to normal badlands fix the shrapnel issue? Loaded non sas question
BlueBronco
DFW
With the exception of the obvious wheels and tires the only other thing you will lose out on are the wider fender flares. Since you are going with the manual BL you will already have the 4.7 gears that the Squatch also adds.
