FTBronco9
F-150
Why does everyone think that the badlands is far superior to the Wildtrak? Other than the stabar disco, a rear steel bumper, thicker skids and an extra goat mode, there’s not much difference. Are those 4 things that big a deal? You can option the thicker skids if you’d like. It depends on what kind of comparison testing they’re going to do right? If they’re just strictly going to do rock crawling then the disco will help. But other than that...
Ripcurl
DodgeRam 1500 Laramie, HarleyDavidson 48
Will we see this by September?
What is your reservation date?
vrtical
Doug
GSMNP, TN
Fords
I am picking the middle blue button
Roger123
Roger
VA Beach, VA
Pure speculation, but a fun discussion (we have no idea what drive modes will actually be like in the real world, the only thing I've seen is professional race drivers giving ride-a-longs) none the less.
I would hope this comparison would include more than exclusively going over the Rubicon Trail. In my opinion I'd like to see a real world day to day use comparison and I'd say a Rubi and WT are pretty damn close to each other (but for the sway bar).
Natai
Sean
Sacramento
Nissan Sentra, Mercedes GLC
I'll echo that this should be Rubicon vs. Badlands, not Wildtrak.
  • The BL is specifically targeted at the Rubicon for off-road and crawling, while the WT is focused on high-speed off-road.
  • BL has the armor already and includes the Rock Crawl GOAT mode that the WT lacks.
  • The Sway Bar Disconnect is an important feature that should be included in any comparison between the Bronco and Jeep.
    • It has a significant impact on crawling, which will be important to the IFS vs SFA discussion, and could play a role in other elements of crawling as well.
    • It has also been shown to have a significant impact on ride quality when off-road, even if not crawling.
    • The ability to disconnect and reconnect under load is likely to be a much bigger point in favor of the Bronco, so should be included in the comparison.
  • You can still Squatch the BL if you want the 35s for comparison.
Squatch
Miami
For a pretty specific use case, sure. I'll bet a SAS Base will wheel to 99% of where a SAS BL will go. It'll just do it on 3 tires more often, LOL.
Sway bar disco re-connects at 20mph, most of my forest service road, beach bombing, snow driving is greater than 20mph. Put manual discos on the Bronco, Done!
Manual disconnects on a $50-60K vehicle????
Good sir, I will not be stepping outside of my carriage and risk scuffing my Louboutins to manually do anything on the trail.
DubleDown
DubleDown
Apex, NC
JLUR, 911S
hi
in the comparaison price WILDTRACK come with sasquash did you forget to add 35 inch tire and a suspension lift kit from MOPAR to jeep compare !
TRACKTOY
Good Point. We will do a MOPAR lift after delivery to "even them up".
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
hi
TRACKTOY
Theoretically 315s will fit on a Rubicon stock, but yeah, the 2.5” Mopar lift would do it for sure.
BossMann
Louisville
2009 Honda Pilot
Rubicon is a designed crawler
Badlands is a designed crawler
Wildtrack is a designed desert racer
it's pretty simple.
DubleDown
DubleDown
Apex, NC
JLUR, 911S
hi
TRACKTOY
TRACKTOY
ANDRÉ
ST-AUGUSTIN-DE-DESMAURES Qc. CANADA
F150 LARIAT CREW C. 3.5L ÉCO 2022+ BRONCO BL.2023
YOU FORGOT TO MENTION marine grade vinyl seat vs cloth seat and wash out intérior and sealed electric connection and the access to high and lux pkg. and other thing.... not only 4 things like you say..... APPLE TO APPLE
TRACKTOY
DubleDown
DubleDown
Apex, NC
JLUR, 911S
Badlands Recommendation noted. Disconnect is a factor. If it affects delivery date, we will downgrade Wrangler to better match Wildtrak.
A big part of this project is not just the crawling and off-roading. It will be about the post purchase modifications and ownership experience. Which things are easier and cost effective. Keep the ideas coming, we are making a list. Here are some examples we have received so far. Let us know what you would like to see. This will be vlogged as well.
Driving Comparisons:
Around Town
Highway
Dirt Road
Trails
-Rubicon
-Moab
-Beach
-Mud
-Snow
Cameras
Radio/Infotainment
Comfort
Visibility
Safety Features
Convenience Features
Easy Stuff:
Taking Doors on/off
Taking Roof on/off
Changing a tire
Adding hardwired dash cam other in cab electronics
Adding Brush/Bull Bar
Lighting
Interior Storage
Medium:
Adding Winch
More Skid Plates
Tire Carrier
Exterior Storage (racks, etc)
Harder:
Gearing
4"+ Lift
40" Tires
Gamecock
it's pretty simple.
Kind of...but WIldTrak has nothing over the Badlands as far as capability as a "desert racer", except a little but of weight reduction with WildTrak which will be unnoticeable. Badlands is more of an all-arounder that has better rock crawling capability than the rest of the Bronco fleet.
