- Keith
- Dec 14, 2021
- 4
- 53
- 91
- Port Angeles, WA
- Bronco Badlands Sasquatch, Bronco Sport, Chev Volt
- Badlands
So early last week I got an alert, "Charging System service soon". I have a grand total of 300 miles on it. I just got all of the protections on and was starting the break in. I took it to the dealership. They found that there is a sensor that is bad and ordered a new one. They likened it to if you have a fuel gauge that reads empty but it's full of fuel. It won't hurt to drive it until the sensor comes in. I will just have to keep hitting "OK" when the alert pops up.
Fast forward 5 days later and the part is in. I go into the garage and there is no power at all in it. No lights come on, nada. I use a battery charger and do a slow charge. In the evening, it has power but wow, it did NOT like it. I had about 8 alerts go off when I hit the ignition such as "4x4 system needs service", "charging system service soon", "service traction control", "brake service soon", amongst others, the headlights flashed once, and the vehicle would not turn over at all. After I got out, it started shaking too as there was a thumping in the B&O system even though the vehicle was off (obviously power running amok). It soon went away as the power drained out.
I'm typing this as I'm waiting for the flat bed to arrive to bring it to the dealer. I understand things can come from the factory with a lemon part. What pisses me off is that I brought it in last week to avoid this very thing. I would have left it at the dealer had this been an issue or possibility. Instead now I am forced to burn a comp day to get this squared away.
**The final solution is on Page 5 if you don't want to see the in between steps and back and forth with others with the same issue.**
