PrevCYBRTRKrez
Jacob
Decherd, TN
2023 4dr Badlands, 2020 Lincoln Aviator
That’s kind of a bummer. My plan was to run like that the majority of time. I may have to look in to the mesh tops now.
Yea they are only secured in the front since their is no middle bar like Jeeps. One of the tradeoffs. I think that canvas bimini top will be very handy.
BroAD
Adam
Illinois
2012 Ford F-150
I was hoping they would add a video with the four door hard top removal as well... never owned a Jeep but looks different since it doesn’t look like the Jeep has removable panels over the rear passenger compartment.
BroAD
Adam
Illinois
2012 Ford F-150
The rear section looked a little flimsy?
I wonder if this correlates to the fact as to why the static and dynamic roof rack weight maximums are so low.
Used2jeep
Massachuvian
2007 Crown Vic P71
13mm, figures that it wouldn't be the more common 10 or 12. However, at least they don't make you use some special factory only tool! Oh, wait....
Used2jeep
Massachuvian
2007 Crown Vic P71
It should be the same way except you have that long second row mini piece to come off before you undo the 4 bolts on the clam shell.
VelocityGator
98 4Runner
Can I run the Bimini under the hard top and have the back section on with the canvas over the front section? I want to run doors off most of the time. Like the idea of sun protection and hope someone (come on Ford, concession for the mod top delay)pops out the side windows easy.
Southern Girl
1974 Bronco/2023 Bronco
Personally, I've been waiting to see how this works. I wish the back windows were removable like the modular top, but it looks pretty easy to remove.
Hoofnmouth
mark
N ca
ford focus st
After watching this video im cancelling my roof rack i can just bolt the rack thru the roof an not have to monkey with the front caps .
Thanks for posting and saving me more $
ethanax
Ethan
Heyworth, IL
F150 Lariat
So it looks like taking the roof rack off is easy enough, but what if you have the LED light bar? Isn’t that also attached to the roof rack or is it separate? If I want to take off the roof rack to take off the roof, will the light bar easily disconnect/unplug? The video is making me think I shouldn’t get the light bar. But surely having a light bar wouldn’t prevent me from ever taking the roof off, right?
t3n2and4
VJ
Washington
www.instagram.com
Badlands, F150, VW CC
I wonder how people that install wheel locks survive? :unsure:
Putting them in the cupholder when you go to get tires. Tell the guy. I know when they finally start: phone rings, I tell them the key is in the cupholder.
t3n2and4
VJ
Washington
www.instagram.com
I was trying to figure that out and realized the solution to that was visible on the Filson Fire Bronco: a little metal bracket.
Kos
Omaha, NE
2022 Ford Bronco Badlands
I think the big question in this is can you operate the latches with the top in place. If so, I don’t see why not.
Bronc-O
Phoenix
2021 Lincoln Aviator
You might have missed my point. A lot of people use wheel locks and manage to hang onto the special tool to remove them. But all of a sudden, a special tool to remove the roof bolts is too difficult to deal with.
