The Venn Diagram of "thinks 20's are a good call for an off-roader" and "thinks super slow, pensive covers of 'Sweet Dreams' are badass" is a perfect circle, and I want to drop-kick both into the sun
Sure,I"m new to all of this. Mind explaining why 17'' wheels are better than a larger wheel?
Taller sidewall on the tire is far better off-road. Lighter weight wheel and tire combo as well.I"m new to all of this. Mind explaining why 17'' wheels are better than a larger wheel?
Daddy Like4" lift with 37s
Looks like when they put the door back on they didn’t get the top of the door hooked in right ..Anybody else notice what appears to be a huge gap between the rear window and B-pillar?
Looks like ??? to me.Can someone explain to me the Additional Overall Height of going from SAS (35") to 4" lift and 37" tires?
Is it a true 4" + the difference in tire size....or ????
It’s all about the rubber.I"m new to all of this. Mind explaining why 17'' wheels are better than a larger wheel?
Manson slowed it down fine, but yeah, I wasn’t digging the video or music. Am I the only one who saw some weird stuff after it was over? If so I’ve got to clear my browser history.The Venn Diagram of "thinks 20's are a good call for an off-roader" and "thinks super slow, pensive covers of 'Sweet Dreams' are badass" is a perfect circle, and I want to drop-kick both into the sun
Wow! that is super helpful! So, based on the above - having the outerbanks package non sas - those tires are still very capable, correct? Living in southern california where it's very dry out here I shouldn't have any issues, yeah?Sure,
For off roading, you want as much rubber (sidewall) as possible, because when you go off road in dirt, mud, rocks, sand, or snow, you want to air down. So, let's say you start with your 37s on the highway with 40 PSI (example). When off roading, you want to go as low as 12 PSI or even 8 PSI if you have beads locked. For light to medium off road trails, 15-20 PSI will be low enough. It improves the ride quality for your back, and makes a larger contact patch.
Off road tires are built to run almost flat and should be driven almost flat off road for going over rocks without puncture (mostly) and to give you much more traction on the ground since these tires have aggressive lugs and tread patterns. This is same for AT or MT (ALL or Mud Terrain) tires.
Also, if you're out in the sticks, replacing a 20" off road tire will be impossible,
Globally, you'd run 16" wheels on 32" or 33" tires and not any larger. Only here in the USA does anyone really wheel with 35s or larger, because MERICA!
Probably not the only one. Tik Tok is a special type of disturbing as far as what people will post there.Manson slowed it down fine, but yeah, I wasn’t digging the video or music. Am I the only one who saw some weird stuff after it was over? If so I’ve got to clear my browser history.
Looks like somehow the door was open with the window all the way up when shut rather than the 1" lowering it normally does. Weird.Anybody else notice what appears to be a huge gap between the rear window and B-pillar?
