jpeml94
Pat
Orange County, CA
Subaru Outback (2016)
Ford Bronco Bronco Overland Concept Revealed! With Live Debut Video & Pics From Super Celebration East 1602200410507
can we talk about the roof rack a second? Why doesn’t Ford extend the rack to the back of the hardtop? Those notches are clearly mounting points, which have been used on the 4door fishing concept (or whatever they want to call it.) Any ideas why they chose to stop the rack 3/4 of the way to the rear? I feel like that back area would probably support substantially more weight being that it’s not tied to the windshield (better distribution of weight).
Catmandu
SW Florida
2013 Jeep JKU (Officially Sold), 2015 Expedition
I gotta admit, I’m a bit confused on this build. I thought the only difference between the sas and non-sas on a Badlands was the wheels and tires. This seems to prove this earlier information incorrect based on the tire clearance.
eBronco
Mr. C
US
2005 Mariner, 2016 CMAX, 2017 F-150 Platinum FX4
"Includes an ARB refrigerator, cooking kit and stove mounted to a cargo management system. The refrigerator has a slide-out tray for easy access, while a tailgate table and chairs complete the campsite."
Sell your house. Buy a Bronco.
Just missing the port-a-potty.
Delasangre
Oregon City
2021 Ranger Lariat Tremor
Is it just me, or does this bronco look like it needs a little lift to clear those tires?
Was thinking the same, if this is the Badlands then it should have a taller suspension than the more base versions, or it has the sasquatch either way if this is as high as it goes from the factory itll need a lift. You almost can't use the swaybar disconnect you just paid so much for...
blue182
Tom
dmv
AMB BD
They use the same rack on the two door as the four door. I believe it uses the back notches on the two door. The back of the hard top is probably the same for the two and four door.
Deleted member 2346
Guest
If those truly aren’t 37” tires, this thing is riding lower than a normal Sasquatch. Too low. No room to flex. Something is off. Wheel gap is less. Added pics of other Sasquatch pkg Broncos. Clearly different.
Ford Bronco Bronco Overland Concept Revealed! With Live Debut Video & Pics From Super Celebration East 1F77B3A0-86CE-41DC-9208-C6B88B107742
Ford Bronco Bronco Overland Concept Revealed! With Live Debut Video & Pics From Super Celebration East C620337F-AA46-455C-9A80-57F02A07E4DC
Ford Bronco Bronco Overland Concept Revealed! With Live Debut Video & Pics From Super Celebration East 763A3B8B-FFBB-4320-8FAE-8EA68420A414
Skagzoola
Washington
Chevy Cruz (POS)
LIVE REVEAL VIDEO! THANKS TO @ATLUTDFAN
WALKAROUND VIDEO:
New Bronco Overland Concept Underscores Ford’s Off-Road Brand Accessories Game at Largest Bronco Enthusiast Gathering
TOWNSEND, Tenn., Oct. 7, 2020 – In honor of the largest North American gathering of classic Ford Broncos, Ford revealed a Bronco Overland concept to kick off this year’s Bronco Super Celebration East in Townsend, Tenn.
Based on the all-new Bronco four-door model, the concept will be on display at the annual off-road event alongside the all-new Bronco two-door and Bronco Sport 4x4 models to give fans a chance to see the only domestic all-4x4 family of off-road SUVs in the metal.
With personalization and factory-backed accessories essential to Ford’s all-new outdoor brand, the Bronco Overland concept showcases how the all-new Bronco two-door, four-door and Sport models are designed to help redefine the next generation of off-road vehicles.
Based on a 2021 Bronco four-door SUV Badlands™ series painted in Area 51 color scheme, the concept is fully equipped inside and out to take adventurers farther into the wild. It features the High-Performance Off-road Stability Suspension (H.O.S.S.) System with Bilstein® position-sensitive dampers, 2.3-liter EcoBoost® engine with class-exclusive 7-speed manual transmission, with 17-inch Fifteen52™ Turbomatic heavy-duty wheels in asphalt black and 35-inch BFGoodrich® LT315/70R-17 mud-terrain KM3 tires for better off-road traction.
Up front, the Bronco Overlander concept features a Ford Performance by WARN® winch mounted to a Ford Performance modular steel bumper to help adventurers negotiate tough, rocky terrain. A heavy-duty two-person tent from Yakima™ and a factory roof rack are mounted to the roof rails with a 1x40 RIGID™ rack-mounted light bar and six additional RIGID POD lights in a 360 configuration for improved lighting all around. A tall CB antenna is mounted to the rear bumper.
The rear is setup to be the center of basecamp and includes an ARB refrigerator, cooking kit and stove mounted to a cargo management system. The refrigerator has a slide-out tray for easy access, while a tailgate table and chairs complete the campsite. The rear quarter window glass has rigid panels with MOLLE grids mounted inside for additional rear cargo area storage.
LIVE PICS FROM SUPER CELEBRATION EAST (COURTESY OF VARIOUS BRONCO6G USERS)
That Area 51 looks damn good! And it's the only color I've seen so far that can handle the hideousness of that grey top. They actually compliment each other quite nicely.
Delasangre
Oregon City
As alot of you have said the Badlands is supposed to have sasquatch height suspension with or without the sasquatch package, that and if it sits that low AND if the sasquatch package adds travel limiters to make sure the 35's clear the fenders then what was the point of the disconnecting sway bar? I am not sure you would even be able to use that feature, makes me want to drop back down to a Black Diamond.
Also I have not seen this talked about, what if you want to do an aftermarket lift after the fact? Will you be throwing the expensive fancy electronic shocks in the trash? Will you even be able to lift all that much with independent front suspension? I was hoping the Badlands with the sasquatch suspension would be enough for me not to need/want to lift it any further but seeing how little gap there is I am somewhat concerned now.
Delasangre
Oregon City
Delasangre
Oregon City
Got it ✔
Sorry about that
I think there’s actually a small difference but probably negligible :)
According to #12
https://www.bronco6g.com/forum/thre...om-being-at-bronco-super-cel-east-today.6364/
Ya they seem to have been speaking in circles and not being very clear. I have heard the BL is between base and Squatch and I have heard it is the same. Sorta makes me want to cancel my reservation and order one in 3 years when stuff is calmed down and all the info and models are out and aftermarket has had a chance. Waiting not so patiently for B&P still...
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
none of the factory options so far have 'fancy electronic shocks'
