Wonder what is the overall height? Over 6’9” as need to stay below that to get into garage
Ya, I think the Sas package is kinda irrelevant in some cases the way Ford designed this. Sas is 5k but a chunk of that money is the rims of which aren't complete until you spend another chunk to get the lock rings. I don't like Sas rims and would rather spend the money and get my own. The only time I think Sas is relevant is if you intend to use the 35's as is and how its intended (rock crawling). If you are just looking for the Sas "look" I think you can do it for cheaper and with your own rims. If you are going to 37s, again going without Sas and making something your own is going to be so easy and you get the shocks, rims, front axle, and tires you want. The gearing and front axle for hardcore 37s will be available from Ford Performance.Goodness sake, this things takes 37s so easily!
That’s why I ordered an AMB, this way I can’t lie to myself that it’s not black.Sexxxxy!!!
Must resist urge to order black....
All depends on what you want and if you are doing the work yourself. Fox coil overs on all 4 corners plus new UCAs installed yourself is probably at least $5K.Stupid question but does anyone have an idea of what this kind of setup would cost? I wonder if aftermarket vs Sasquatch which would be better for the money if they are relative in cost.
