Bronco ProComp Rear Track Bar, Upper Arms, Fox Shocks, Eibach Springs + 37" Tires
PDiddy
Paul
4Runner
Yeah, that’s one sexy truck on 37s. Dang.
ssolypop
Solomon
Hawaii
Avenger
ProComp Upper Arms
Fox Shocks
Eibach Springs
37" Nitto Grapplers
wow......
Looks so good, would it be weird for me to hug one of the tires ?
MaverickMan
Shane
That looks awesome!
EvlNvrDys
Hunterdon County, NJ
wvmtneer
‘Merica
F-150
KH_59
Kevin
pearland tx 77584
F-150
Looks like it could use slightly longer rear suspension trailing arms (or perhaps, some sort of "drop-bracket" arrangement) to push the axle back to the centerline of the fender arch.
vrtical
Doug
GSMNP, TN
Fords
new style nut lock
pan-y-cerveza
Manitoba
Tacoma Pro
Looks like a quad and not in the good way.
I'll stick with my 32s for now.
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
Ford Bronco Bronco ProComp Rear Track Bar, Upper Arms, Fox Shocks, Eibach Springs + 37" Tires 1611673840193
Seeing a few comments from people that may not realize the rear is on jack stands. This is near full droop for the rear. It does not have this stance or have an obvious offcenter rear axle when at normal compression.
Raptor911
Raptor911
Broadlands, VA
It looks good but the angles are too severe (even sitting on flat ground). Once you articulate the front suspension you are going to do damage to the hubs:
Ford Bronco Bronco ProComp Rear Track Bar, Upper Arms, Fox Shocks, Eibach Springs + 37" Tires 1611674260275
Razorback
Bill
Dallas
Lincoln MKX
I thought the same about the rear and then saw what appears to be a jack. Guess they are just checking rear fender clearance...
