I'll start with I have a 2021 4DR Wildtrak with the 2.7 and I live in Arizona.
Does anyone know what temperature the radiator fan is supposed to kick on in the Bronco?
Here is my issue.
I have recently noticed that my Bronco runs in the temp around 220-225 consistently while driving around and may fluctuate a little based on how much turbo otherwise but usually I'm not into the turbos.
What I dont understand is at that temp my engine fans are not running.
If I have my A/C on than my fans stay on and keep the engine temperature between 195 and 200 and sometimes just a little over 200 but then will go back down after a minute of no turbo usage.
Is this normal for the Bronco as my fan only seems to run when my A/C is running? I noticed this the other day with the windows down and the AC off and the vehicle was much warmer and I finally found out why for my vehicle.
Here is my issue.
