Bronco Raptor Bumper Fog Adapters and Conversions... We have what you need... NOW... Look..
SPVPARTS
Lux Sponsor (Level 2)
Greenwood, IN
specialtyperformanceparts.com
Ford Raptor/Bronco/Mach E
So we get a ton of requests for adapters to plug into the factory Fog connectors of a Bronco that someone has put a Bronco Raptor bumper on, or they simply got some of the fog pocket lights as take offs to put in them.
For those of you in that situation, we have the adapters and harnesses you were trying to find.
Lets go through the list. If any of this DOESN'T makes sense, or you simply need help, please reach out. We are happy to help.
Email - info @spvparts.com Phone- 317/934/6778
Option 1: Vehicles that CAME with a Modular Bumper-
So, for those of you with a MODULAR bumper already, you should have the prep connectors. Those are the ones you have read about on here that you need to buy a Ford headlight switch with Fog button and to use FORSCAN to program them. These adapters plug into those, and then they have the same 2 Pin Molex connector that Ford uses on the OEM Rigid lights.
https://specialtyperformanceparts.c...o-prep-fog-connector-pair-modular-bumper-only
Now, that is ONE Molex connector right? You have 2 pairs of lights. So from there, you can go 2 different routes.
You can add these Molex Splitters to have all 4 on the one switch-
https://specialtyperformanceparts.c...-oem-fogs-combine-both-pairs-to-1-switch-pair
OR
You can add our Single Pair Fog harness (With Standard Connectors)
https://specialtyperformanceparts.c...s-system-works-with-many-vehicles-see-details
And then these Molex 2 Pin adapters to plug into it for a separate fog switch-
Option 2: Vehicles that came with a Standard or Capable Bumper
Now, lets say you have a Capable or Standard Bumper with Fog lights.
Those trucks have the H11 Connectors. So you can get an H11 Fog to WP 2 Way adapter here-
https://specialtyperformanceparts.c...to-h10-factory-fog-connector-pair-see-details
And then convert that to a Molex 2 Pole Adapter here-
That, like the previous with the Prep connectors gives you ONE connection. From there, you can choose to split them into 2 so you have all 4 on one-
OR
And then these Molex 2 Pin adapters to plug into it to have them on a separate fog switch.-
Option 3: Vehicles that originally had NO fog lights and have NO fog connections in the bumper, or if you just want them all on one switch.
We have our OEM Fog conversion harness with Molex Adapters-
https://specialtyperformanceparts.c...-gen-3-oem-fog-plug-n-play-conversion-harness
And that puts each pair optionally on a separate switch. You can add one of these splitters up top to combine them into one switch. You can then plug them into your Aux switches or add a switch panel-
When it comes to wiring... We have an option for just about ANYTHING you can come up with for your lighting solutions via our plug n play harness system.
So reach out with questions!
Glenjafett
Atlanta
2023 Bronco
Nice set up. I had to make my own a year ago and tracking down all the connecters and pins was a pain. I'm sure this will be helpful.
SPVPARTS
SPVPARTS
Greenwood, IN
Thanks,
Yeah there are a lot of requests. Trying to cover all the bases sometimes takes some thinking. We will continue to come out with more options like this and often there are 2 or 3 ways to accomplish the same feat. Its just figuring out the most simple solution. We may come out with a direct H11 to Molex 2 pin connector rather than the 2 adapters into the one if it is something that is popular, though right now. This solution is ready and available.
misterspivey
Bud
WA
Thanks John @SPVPARTS .
This is what all of us modular bumper owners have been looking for to install the Raptor Rigid fog lights.
In fact I called SPV on Friday asking if this type of wire bundle was available. It wasn't so I bought one of your other prep bundles for the modular bumper with the WP connector, planning to cut off the WP connector and install another 2 pin MX150 connector. Just got done ordering my connectors, pins, crimping tool, etc last night when I saw your post. So I just ordered the new bundle.
misterspivey
Bud
WA
Just installed the https://specialtyperformanceparts.c...o-prep-fog-connector-pair-modular-bumper-only along with the splitter https://specialtyperformanceparts.c...-oem-fogs-combine-both-pairs-to-1-switch-pair to accomplish the Raptor Rigid fog light install in a regular Bronco modular bumper and have both pairs of lights controlled by the headlight switch. The wire bundles saved a ton of time and turned the installation into a piece of cake. I was planning on taking some pics and doing a video but I was already done before I had a chance to think about taking pics. The wire bundles appear to be high quality.
Make sure the pins are locked in the PREP connector before mating it with the receptacle though. Mine weren't locked. Look inside the connector to confirm that the white plastic keeper is depressed and flush with the mating face. Or just try pulling the wires out of the back of the connector to ensure they're locked. If not, push the wires into the connector to seat the pins and then push the white plastic piece into the connector to lock the pins.
SPVPARTS
SPVPARTS
Greenwood, IN
I thought it might be a good idea to direct you guys to this post as well with UPGRADES for your OEM Fogs in the Bronco Raptor Bumpers you are converting.
These options keep the same look, but give you a lot more power. In your case, the application will be the same, however, since your Fog connectors are different. Just contact us and we can put together a custom set up with the adapters to match your original harness. Since these kits are designed to fit the Molex connectors in the Raptor harness you are converting FROM. Technically you can still get the adapters on this page and then plug them into the other adapters, but there is no sense in that if we can just swap for the proper ones.
https://www.bronco6g.com/forum/thre...-sr-m-diode-dynamics-ssc2-baja-designs.96352/
SPV Parts
317/934/6778
Info @spvparts.com
